new pump installed
Old Dec 31, 2010 | 07:26 PM
black05scamg's Avatar
2005 e55 black on black 07 e63 po30
new pump installed
hey guys happy newyear i installed my ic pump today.
i used a cobra pump which is allmost the same but the housing is
not so i pull off the housing from the pump and i put it on the new one.
then i spliced the wires becuase the plug is not the same and i ran a wire
to it so i can bleed the system q when i bleed the system i did it with the car off and i waited to see the coolant to come out and then i capped it
but when i turn my car off i do not hear my pump come on for 10 secs
Old Dec 31, 2010 | 08:35 PM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Don't worry unduely. Had those doubts too. Test the car under full power. If it sustains full thrust after backing off the throttle and going back back on the gas, then all should be well.
Brgds
Old Jan 6, 2011 | 09:54 AM
tarekc's Avatar
E55 AMG
Brgds
hey i gonna install n ic pump in my 03 e55 amg ? i didnt know about bleeding the lines?
the collent come from the maid rad ? is the main rad conected to the HE?
is there anything important i should know?
thanks
Old Jan 6, 2011 | 01:32 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
yes the systems are inter connected. so to bleed the system get the car up to operating temp so the IC pump is activated connect a hose from the bleed nipple by the s/c to the coolant reservior and let the car idle to get ride off all the air in the system.
Old Jan 7, 2011 | 03:13 AM
tarekc's Avatar
E55 AMG
thanks
sorry is the coolant reservoir where you add water to the radiator? (and the water lost when changing the IC pump is added where you add water to the radiator??)
and so u have a pic of the bleed nipple or a link to a pic?
thanks again
Old Jan 7, 2011 | 03:29 AM
tbal's Avatar
Haters crazy
which cobra pump did you use
Old Jan 7, 2011 | 04:08 AM
Viet_Amg408's Avatar
Pinto
i have cobra pump too...
bleeding is a plus.but not neccessary .because mercedes cooling system auto bleed itself...
top off the coolant in the reservior and drive it couple hard pulls so the ic pump run ..come back and top the fluid off again..
Old Jan 9, 2011 | 02:39 AM
OK55's Avatar
There is a bleed nipple incorporated so I guess Mercedes must have intended bleeding as part of the process.
Pls see this link for more details https://mbworld.org/forums/w211-amg/...-pump-e55.html
The Mercedes part no of the new upgraded Intercooler coolant pump is 000 500 03 86.
Old Jan 12, 2011 | 09:02 AM
tarekc's Avatar
E55 AMG
HELP !!!!!!!!
hey i just installed my new mb ic pump cuz i thought that was my problem!
my car accelerates fine up to any speed i want as long as i acc slow, sc working fine...
soon as i hit the gas hard i can feel lots of power loss then the sc cuts out and the car start puttin and im scared to drive it!!
is the a fuse or sensor for the ic pump or could my problem be some type of sensor?
any ideas???
THANKS!!!
Old Jan 12, 2011 | 01:29 PM
Pinto
Sound like you IAT is high..computer open bypass valve (let off the boosst)
Seem like the car just take a dump when you hard on throttle..righht?
either the new pump is bad..did you test it before installing it?
double check your install?
or you have air in the system..
Old Jan 12, 2011 | 04:04 PM
tarekc's Avatar
E55 AMG
yeah, its a brand new bosch pump the new version ! the install is done proper i bled the lines too maybe theres no power reaching the pump n it wont turn'? afuse or a sensor maybe??
Old Jan 12, 2011 | 04:05 PM
tarekc's Avatar
E55 AMG
im not sure the car was at very high temps when i bled the lines i warmed it up for 10 mins and gave it a few hard pulls is that enough>?
Old Jan 12, 2011 | 04:46 PM
Pinto
CHECK YOUR FUSE AND RELAY BOX IN TRUNK...
(F4) AMP=15.. CHARGE AIR COOLER CIRCULATION PUMP..
IF THATS GOOD.. CHECK RELAY (A)..
GOOD LUCK
Old Jan 13, 2011 | 12:35 AM
tarekc's Avatar
E55 AMG
whats relay A ???
thanks
Old Jan 13, 2011 | 03:16 AM
tarekc's Avatar
E55 AMG
hey i check fuse 4 it was 7.5amp and fine ? i got the 03 e55 amg maybe not the same as the S!
i also pulled out relay A in the same fuse box in the side panel of the trunk! how do u know if its working?
put it back in actually got 3-4 full power pulls was loving it then power lost and then sc shut down.
but it was the first time i get full power since the problem occurred???
also in the main fuse box under the hood i pressed all the fuses and relays down, couple seemed a bit loose!
any suggestions?
Old Jan 13, 2011 | 03:31 AM
Pinto
any suggestions?
swap out another relay..
not sure what else could be wrong....i would go back double check your work; look at the pump again..bench test the pump make sure it work..
Old Jan 13, 2011 | 03:32 AM
tarekc's Avatar
E55 AMG
ill try swapping, then run through the system again.
thanks
Old Jan 13, 2011 | 06:15 AM
tarekc's Avatar
E55 AMG
hey i tested the power wires going to ic pump and there was NO power, also i dont think the miny rad fan is working either (no power!!!) i switched the relay A no diff.
so we know there a power problem??
