Help with Rear Main Seal
Can anyone give me a link or tell me where to buy parts needed for this repair?
Thanks!
My leak turned out to be transmission fluid and came from the plastic collar on the side with the two o-rings.
You need:
End cover
new bolts for flywheel as they are stretch bolts
the seal itself
trans fluid as you have to drop the trans and drain
might as well do oil change when your there as when you remove the end cover you will lose some oil
when you have the trans out might as well flush it, change the trans filter, and do the electical plug as well.
Also check that your indy has the trans tool to check fluid level.
Not a fun job and very time consuming...
Last year they also replaced some transmission seals: Parking pawl seals, conductor plate, transconnector. This was a costly job, and it sounds like it may have been beneficial to have done this work then.
Matter in fact I did my valve gasket seals a few months back! You are spot on. How is this labor wise? Does the tranny still have to be dropped to do so? Any more detailed info on the parts, procedure etc?
Thanks Mbtek, you always have some insightful and accurate info!
MBZ Rear Main Seal Replacement:
R&I Transmission
R&R Rear Crankshaft Cover
R&R Rear Main Seal
R&R Flywheel Bolts x8
R&R Transmission Line Seal x4
R&R Pilot Bushing
1 Qt of Mobil 1 0w40
1 Qt of Transmission Fluid
Mercedes Benz Sealant
I have an extended $500 ded warranty that should cover this repair. However, it expires in 4K miles. So, my question is, should I just bite the bullet and get the repair done now or prior to the expiration? I really like this little car and have enjoyed driving it for the past year, so I'd prefer not to sell.
I've been reading some of the other C55 maintenance threads, and just saw one about a "bent" crankshaft that appeared out of nowhere, no warning, and is going to cost $7K or better to repair......this has me concerned about letting this kind of leakage evolve.
The car is a stock C55 AMG with 73K fun miles. It has been dealer maintained, and is otherwise in good shape. Just had my A service done (for $700 no less, needed some filters and work on the washer system).
Thanks in advance, all responses will be gratefully appreciated.
