Strange Noise E55 AMG
Old Jan 19, 2011 | 10:00 PM
jmb614's Avatar
E55 AMG
Hello all! New member here, just purchased a 2006 E55 AMG a few days ago.
After doing a bit of research on the forums here I'm still stumped as to what this noise could be.
I get home from work and park it in the garage and go inside. An hour or so later I go out to the garage to grab something and hear a noise coming from the engine compartment of my vehicle. Every 10 seconds I hear a noise that sounds like an old school printer zipping back and forth, the noise lasts approximately 2 seconds, then repeats 10 seconds later.
I start the vehicle, and feel the front end of the car raise. I've never noticed this before. Does the vehicle drop down while parked and then raise back up when started? Could the noise be an airmatic issue?
Has anyone else heard this type of noise before and knows what is causing it. The PPI checked out fine, but now I'm wondering if I should take it back in for another inspection.
Any help is greatly appreciated.
Old Jan 19, 2011 | 10:03 PM
03'55AMG's Avatar
AMG
yes, the car lowers when you leave and vice versa when you get in, but evey 10 seconds? idk..
Old Jan 19, 2011 | 10:06 PM
jmb614's Avatar
E55 AMG
After shutting the car off I no longer am hearing the noise. Gremlins?
I stood there for about 5 minutes listening to this noise that would occur every 10 seconds, without fail. Very odd...
Old Jan 19, 2011 | 10:13 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
airmatic pump
Old Jan 19, 2011 | 10:17 PM
Bellevue_E55's Avatar
2006 Mercedes E55
Had this happen last week and posted similar thread. Somebody said secondary air pump as it was at the front right of engine. I started car and has never come back
Old Jan 19, 2011 | 10:29 PM
snail45's Avatar
E55 AMG
Originally Posted by shardul
airmatic pump
Yup. It does what it wants. Its best to let it be.
Old Jan 19, 2011 | 10:33 PM
GT-ER's Avatar
2005 E55 AMG
Interesting...maybe you have a leak? My airmatic pump rarely ever goes on with the car off ( it does sometimes but maybe once every few hours or so ). As a matter of fact, I get in the car the following morning and the car doesn't have to level it's self out like the op's does.
Old Jan 20, 2011 | 08:11 AM
jmb614's Avatar
E55 AMG
Thanks for the replies! I got in the car this morning and it didn't have to level itself out. Perhaps it's beginning to fail? Should I leave it be for now as someone here mentioned, or take it in and have it looked at?
Old Jan 20, 2011 | 09:07 AM
GT-ER's Avatar
2005 E55 AMG
I'd leave it alone honestly, just let whatever may be failing ( if anything ) fail completely and then replace.
Old Jan 20, 2011 | 09:44 AM
izzyz28's Avatar
2004 E55 AMG
Do this. Taking these cars in for something that seems weird that may have partially failed typically results in no issues being found and a lot of wasted time and effort. If it is really an issue it will get worse and worse until something is definitely broken(or nearly broken), which makes diagnosis far easier.
Old Jan 20, 2011 | 10:47 AM
mthis's Avatar
Anything W/4Wheels
Got the something on my 63. But mine only comes on after 1hr or so
Old Jan 20, 2011 | 10:57 AM
jmb614's Avatar
E55 AMG
I suppose I will let it sit for now; thank you for the help! I look forward to being an active member of the community!
Old Jan 20, 2011 | 12:41 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
My 55 is stored for 6 months each year while we're at our other home. There is a battery maintainer connected, but at some unknown time into the storage period the Airmatic system deflates. The moment I turn on the ignition I get the "RED AIRMATIC WARNING", the air pump immediately turns on and all is once again normal. I suspect there is a programmed system shutdown if the ECU sees no activity after a specific time.
