Keyless Go Engine start
Old Jan 25, 2011 | 04:31 PM
lybones's Avatar
Black e55
I purchased my E55 last year and was wondering if my Keyless Go engine start was an option or was removed. I can open my doors with the key in my pocket, but does nothing when I step on the brake and press the engine start button on the shifter. The previous owner said the engine start never worked for him. Any thoughts on this? I'm completely lost with this issue. Thanks
Old Jan 25, 2011 | 04:35 PM
Evolved8's Avatar
AMG Fam
sounds like it needs to be looked into at the dealer $$$$
Old Jan 25, 2011 | 04:37 PM
gambari's Avatar
05 E55, 08 S63, 09 GL450
I doubt that it was removed, but most likely just a defective Keyless Go. You should have it diagnosed as it might be the shifter (the case with mine) or something more involved. Depending on where you reside, you might actually find good recommendations from this forum on who can take a look-see for you.
Good Luck...
Old Jan 25, 2011 | 04:38 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Sounds like the switch in the knob is defective.
Old Jan 25, 2011 | 04:40 PM
lybones's Avatar
Black e55
Good Luck...
good Point. I'm in orange county, Ca. That would be great if anyone has had experience with this around my area. Thanks again.
Old Jan 25, 2011 | 04:56 PM
KLR CLS's Avatar
CLS63 PP
I agree..probably the button on the knob.
Old Jan 26, 2011 | 11:14 AM
Dan Wang's Avatar
I have an extra keyless go shift knob and boot if you are interested.
I'm in Orange County also.
Old Jan 26, 2011 | 11:51 AM
lybones's Avatar
Black e55
How Would I check to see if the knob button is broken?
Old Jan 26, 2011 | 03:03 PM
Dan Wang's Avatar
SDS might be able to see if there is a problem. The dealer would be able to hook it up and check.
Otherwise, you're more than welcomed to try out the shift knob I have for sale to see if would work for your car. If it works, pay me for the knob. If not, you don't have to buy it. I'd charge you a 6 pack of beer for my time thought. Kidding.
Old Jan 26, 2011 | 03:21 PM
lybones's Avatar
Black e55
sounds good. I first need to figure out how to remove the shifter ti diagnose the button.
Old Feb 18, 2011 | 01:32 AM
lybones's Avatar
Black e55
Do you still have the shifter?
Old Feb 18, 2011 | 01:36 AM
Dan Wang's Avatar
Yes I do.
Old Feb 18, 2011 | 07:04 PM
03'55AMG's Avatar
AMG
If you want to remove the button, just remove the ashtray (if applicable) and pull up on the lip on the wood around the shift knob, and it should pop right off allowing access to the button
Old Feb 19, 2011 | 05:13 PM
lybones's Avatar
Black e55
Yes I do.
Great! When can I get it?
Old Feb 21, 2011 | 09:23 PM
lybones's Avatar
Black e55
shifter removed
Is there a way to test if it is indeed the shifter button that is broken after removal? Thanks
Attached Thumbnails Keyless Go Engine start-photo-1-6.jpg   Keyless Go Engine start-photo-2-5.jpg
Old Feb 22, 2011 | 07:54 AM
Hellzno's Avatar
E55 AMG
you can ohm out the button to the push button start. You need a multimeter and maybe someone can tell you what wires to test.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
