Hesitation at Low RPM
Old Jan 25, 2011 | 06:40 PM
jmb614's Avatar
E55 AMG
I've read a few threads on this but I'm still not sure I have a handle on what could be possibly causing this.
Whenever starting from a dig or rolling at low speed, <15 mph, and I stomp on the gas, there is a slight hesitation at around 1500-1700 RPM, just for a second or so, enough to throw my head forward, then the car quickly takes off again as if nothing happened.
Any one had this issue and correctly diagnosed the problem? Thanks for the help!
Old Jan 25, 2011 | 06:46 PM
03'55AMG's Avatar
AMG
happens to me when i stomp it when the engines cold, then found out its bad and stopped doing it right there.(did it twice)
Old Jan 25, 2011 | 06:48 PM
jmb614's Avatar
E55 AMG
I've always waited until the engine is up to proper operating temperature before mashing on anything.
Old Jan 25, 2011 | 07:03 PM
Hyperlite's Avatar
2005 E55 AMG
Are you in s/c/m?
While in those modes, how are you driving, ie: Drive/Manual?
I've only gotten that kind of jerk when I first got the car and would try and floor it in sport mode "D".
I think it's just the car's weird shifting, though I could be wrong.
I physically shift up and down when driving in sport and since I cruise around in 2nd and you don't really "floor" e55's.
Old Jan 25, 2011 | 07:08 PM
AWOL's Avatar
e55
traction on or off?
jmb614's Avatar
E55 AMG
Originally Posted by Hyperlite
Are you in s/c/m?
I've had it occur in both s and m modes. In M mode it didn't matter if it was in first or second gear.
Old Jan 25, 2011 | 07:09 PM
jmb614's Avatar
E55 AMG
Originally Posted by AWOL
traction on or off?
Traction control on. Let me guess, ESP is the culprit here?
Old Jan 25, 2011 | 07:13 PM
AWOL's Avatar
e55
just try it with esp off, see if it happens. Youll probably spin, but its worth a shot to rule that out
Old Jan 25, 2011 | 07:16 PM
jmb614's Avatar
E55 AMG
Good point, I'll find an empty lot and give it a go.
Old Jan 25, 2011 | 07:17 PM
03'55AMG's Avatar
AMG
nahh just find a red light..
Old Jan 25, 2011 | 07:20 PM
Hyperlite's Avatar
2005 E55 AMG
IMHO, "M" mode is about as far from manual as you can get.
In "S" I can put it in second and it will hold second until I decide to shift.
And when I mean D or M when you are in sport mode I am referring to whether you are leaving it in "D" while driving or shifting while still staying in sport mode.
I've found that In sport mode on "D" there is a hesitation but when I am in sport mode and shifting myself I experienced no hesitation.
Old Jan 25, 2011 | 07:23 PM
03'55AMG's Avatar
AMG
^^ will it hold all gears in S?
Old Jan 25, 2011 | 07:26 PM
Hyperlite's Avatar
2005 E55 AMG
When I'm shifting manually in sport mode It holds the gears until I shift period.
So yes even when you redline it will not shift until you do it yourself/
Unless you are in "D" that is...
The reason I prefer sport is because manual mode does not hold gears contrary to its title, if the rpms drop low enough it will auto-downshift which ruins the fun of cruising around in second and hearing the exhaust when you let off the gas.
Old Jan 25, 2011 | 07:35 PM
03'55AMG's Avatar
AMG
yea i always hated how it shifted down automatically in m, although i recall i did try shifting in S with the paddles on the wheel with no response, is it only with the gear selector?
Old Jan 25, 2011 | 07:47 PM
Hyperlite's Avatar
2005 E55 AMG
On mine, the paddles work just as well.
Old Jan 25, 2011 | 08:14 PM
03'55AMG's Avatar
AMG
maybe thats a difference from the 2003s to the 2005s
Old Jan 25, 2011 | 08:31 PM
jmb614's Avatar
E55 AMG
Turning ESP off did the trick. Thanks everyone!
Old Jan 25, 2011 | 08:53 PM
03'55AMG's Avatar
AMG
darn computers kill all the fun! good to know it worked.
Old Jan 26, 2011 | 12:41 AM
skratch77's Avatar
2005 E55
Pretty sure mine downshifts on its own in M and S and even C,its supposed to or the engine will stall.
Like if your in second doing 20 and slow down it will go to first no matter what,if it didnt the rmps would be forced to go to like 200 and make it stall.
Oh and for the op,its the traction control thinking on how much torque limit it wants to give you before you end up sideways.
Old Jan 26, 2011 | 03:29 AM
Hyperlite's Avatar
2005 E55 AMG
Not trying to insult you or anything, but I know for a fact that is completely wrong.
I do my daily driving cruising around in 2nd gear and I can go anywhere between 0-70 easily without any shifts and it does not stall the engine.
Even in heavy traffic in 2nd gear when I come to a complete stop and then let off the brakes to roll slowly there is no stall.
You did say you were pretty sure so I'm guessing you are just mixing up M mode and S mode because I am 100% sure, it's how I drive on a daily basis.
Old Jan 26, 2011 | 05:17 AM
Mantooth's Avatar
2004 E55 AMG
Comfort takes off in second gear, anyway. Never has stalled before.
To the OP, I was going to guess your ESP or the S/C clutch engaging.
Old Jan 26, 2011 | 08:56 AM
jmb614's Avatar
E55 AMG
Thanks! Is it supposed to do that even if I'm not flogging on the throttle? I still notice it simply cruising about town, but it's not as pronounced, same RPM range however.
Old Jan 26, 2011 | 09:50 AM
buckeyewalt's Avatar
E63,,,not any more,,,BMW X5 50i
If you look at some of the posts here, hesitation is one of the major complaints. Driving a "63", mine is still not fixed. I read on the SLS board, where you have a guy in a new SLS with the same fault. Probably electronics, but what???? I think adaptations is probably the key!
Old Jan 26, 2011 | 09:55 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Auto downshifting in M mode should only happen when the engine approaches stall speed in that gear, otherwise the gear should be held... trailing throttle in second gear as you decrease speed does sound pretty in a tunnel
The holding of gear on upshift varies across year models and EGS tunes. For example my OEM 06 would hit limiter in manual, and auto upshift in S at pretty much power peak. Now with Kleemann EGS "mod" (for 2.82 diff and sharper shifts), even in manual I cannot hit the limiter, which is not necesarily a bad thing, as hitting the limiter in first cannot be good for anything. Auto upshift in S is fair enough. C ? who ever uses C?
I was going to say the title is a contradiction in terms for this car but figured it was either car shifting to 1st from second or ESP.
Old Jan 26, 2011 | 09:56 AM
jmb614's Avatar
E55 AMG
I'm pretty sure it is ESP, as I did not experience the hesitation with ESP off.
