sprak plug wires
Old Feb 6, 2011 | 03:06 AM
black05scamg's Avatar
2005 e55 black on black 07 e63 po30
sprak plug wires
does anybody know the oem part number on the spark plug wires
thanks
Old Feb 6, 2011 | 08:29 AM
06E55's Avatar
2006 E55, 2012 Bentley Continental Supersports Convertible, 2014 Kia Sorento SXL AWD
1121500118 (9) 31.62 ea
1121500218 (4) 25.30 ea
1121500318 (2) 26.45 ea
1121500418 (1) 28.75 ea
Prices are from parts.com
This is for an 06. Not sure if they are the same for an 05...
Old Feb 8, 2011 | 06:45 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
How easy are these to replace? Stealer said a few of mine had deteriorated and were causing a lumpy idle via a misfire and that i should replace them all?
Old Feb 8, 2011 | 06:36 PM
no hard at all just pull the wire from the metal piece not the wire and they should pull out
Old Feb 9, 2011 | 01:12 PM
dkindrumr's Avatar
2003 E55 AMG
Got my set of Bremi Wires on Partsgeek.com Made in Germany and alot less $$$. Installation was seamless
Old Feb 9, 2011 | 03:57 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
anyone know when this expensive buggers start to go bad? (miles)
-Chad
Old Feb 9, 2011 | 04:12 PM
dkindrumr's Avatar
2003 E55 AMG
MBZ says plugs @ 100k, not sure of the wires, I just did them along with the plugs since it was a good time to swap em out
Old Feb 9, 2011 | 06:16 PM
I Like Soup's Avatar
2003 E55 AMG
I did my plugs and wires at a little over 50K miles. I got the whole set of wires for around $160 on parts.com, if memory serves me right.
Old Feb 9, 2011 | 08:50 PM
Jasoneo5's Avatar
W211 E55
Can all the plugs from parts.com also, and should I be able to do the plugs myself? I'm at 99k right now and I kind of noticed a small sputter at an idle the other day...
Old Feb 9, 2011 | 10:16 PM
jmb614's Avatar
E55 AMG
https://mbworld.org/forums/w211-amg/...lug-wires.html
Old Feb 10, 2011 | 07:04 AM
Alps's Avatar
nice one jmb614, just what i needed!
Old Feb 24, 2011 | 12:41 PM
Silverx69x's Avatar
2005 E55
I have an 05 E55 as well and looking to do the plugs and wires. Where did you end up buying the wires from?
Old Mar 10, 2011 | 01:46 AM
Jasoneo5's Avatar
W211 E55
What are some obvious signs of bad spark plug wires? Car just hit 100k like I said and I'm going to do the plugs this week......trying to decide whether or not I should just buy the wires and do them at the same time or see how much longer they will last
Old Mar 10, 2011 | 11:15 AM
2003 E55 AMG
If you are in there, you might as well do it.
Old Mar 10, 2011 | 05:51 PM
jmb614's Avatar
E55 AMG
At 100K miles I would also replace the wires.
Old Mar 11, 2011 | 10:51 AM
Alps's Avatar
Bosch equivalent part numbers for those who need them
0 356 912 950 x 4
0 356 912 952 x 2
0 356 912 948 x 9
0 356 912 954 x 1
Old Mar 11, 2011 | 11:12 AM
ohlord's Avatar
The wires last longer than
100k miles. They are not 100k replacement items nor items replaced every plug change at 5years.
If for some reason you think it is damaged by abuse (like yanking it off the plug by hand) or heat(rarely) test it for proper resistance with your multimeter.
Don't use multi tip plugs,don't use anti-seize,use a swivel socket spark socket,use the 17mm boot tool.Flip the tool around and use it to pop the metal collared boots back onto the plug.
Easy job on a Saturday morning.
Old May 22, 2018 | 11:11 AM
Das Geld 2's Avatar
SL55, S500
Sorry to bump, I was gonna tackle plugs myself on the SL but scraped all my knuckles.
My indy saying change the wires with my plugs, pretty sure my plugs and wires OEM from 2004 70k miles..thats 14 years..
Should I just do the wires while im at it? I see Bremi wires for 160$ Anyone use these?
Old May 22, 2018 | 12:12 PM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
I can't imagine you couldn't pull the wires off the plugs other than you have huge hands or were doing it wrong.
I'd leave the wires be if they don't cause you troubles. If it ain't broke, don't fix it.
Old May 22, 2018 | 02:09 PM
Das Geld 2's Avatar
SL55, S500
Tight in the rear, I used the 17mm. Then realized my torque wrench was defective..It wasn't clicking so I threw it in the trash. Rather pay a shop the $200.
He's insisting I get the wires, I don't feel like it and they looked fine to me when I inspected them as well.
Feel like he won't change my plugs if i come w/o wires hahaha
Old Aug 18, 2018 | 04:52 PM
zhmorrow13's Avatar
W211 E55 AMG
Does anybody know the wiring order? I found this diagram on the ML forums, seems legit. Just want to confirm
