Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: Why is My Car Hesitating?
Step by step instructions for do-it-yourself repairs
Bucking/Hesitation on heavy acceleration...
W211 E55K, Duc 848
No it's not the supercharger "clutch"... No it's not a vacuum leak, and it's def not the actual gas pedal or throttle body. What could it be, bad fuel pump? You can go through the whole rpm range on light throttle, but the second you try to hit the gas pedal as the car was meant to be it just bucks and hesitates and doesn't do anything.... Anyone have some input for this situation at hand.
I also don't think it's the transmission... Thanks in advance guys.
1 Post
His wife crazy
That is how my current issue started a few months ago, and I thought it was a bad tank of gas. Then the ESP malfunction related to the TB actuator last week. I think they are both related. Do you have a sprint booster by any chance?
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Fortunately for E63 owners we don't have that problem, sorry that I can't help you.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
https://mbworld.org/forums/w211-amg/...esitation.html
I had somewhat similar problems and the dealer said it was a slight misfire. They didnt fix anything, but when I got it back, everything was fine. Make sure all the plug wires are tight, and if they are, maybe swap the sparkplugs? Thats what they recommended before trying coil packs.
2003 E55 & 2014 GL550
Worth a try to do Sneaky ECU reset...which is TCU reset.
Also worth it to try battery disconnect for half hour and then reconnect and DONT FORGET to resync ESP (start car and while in park, turn steering wheel end to end a couple times each way. Otherwise you will get ESP Check Engine Light) Search for resync process on windows and sunroof as well.
Otherwise, pull those codes. Could be a million things going on in these sensor packed cars.
W211 E55K, Duc 848
I have used SDS. No codes, No Cels. I'm thinking it's a bad fuel filter/sender unit. No belt slippage. ESP on/off no difference. Hmm...
Odd no codes, so rule out misfires fuel & spark, sounding like the TCU (torque limiter) /transmission.
Do you have the tool to check your trans level?
I had that under heavy acceleration, as soon as car got up in RPMs, car just started bucking until I let off the gas. My two fuel pumps were replaced. they were dropping pressure at high rpm.
E63,,,not any more,,,BMW X5 50i
Guess you never read any of the posts from Buckeyewalt, have you.
Because these cars are drive by wire, throttle opening VS. pedal position is not linear. The signal from the throttle pedal is viewed by the ECU as a torque request. If the pedal is pushed to say 50% very quickly, the ECU sees this as the driver demanding XXX amount of torque very quickly, so the ECU might open the throttle 80% very quickly to fulfill it's calculated torque request based on the drivers input. If the pedal is pushed to 50% very slowly, the ECU may only open the throttle valve 35% much more slowly. Re-mapping throttle response tables will help make throttle valve opening Vs. Pedal position more linear (but not a 1:1 ratio in both opening and speed like a cable operated throttle) and will also remove the "dead" spot at the beginning of pedal travel that all drive by wire MB cars inherently suffer from. Throttle mapping will not, however, remove the ECU's ability to adapt to a specific driving style. ME9.7 cars like your E63 seem to adapt to changes much faster compared to the old ME2.81 V8 Kompressor, but the ECU will still adapt to your driving style.
I don't know of any tuner able to completely disable the adaptive function of these ECU's. I've had discussions with KLEEMANN's programmers about this, and unfortunately, they've not been able to figure out how to disable it- why I don't know, but I suspect this feature is not controlled by the same EPROM that is programmed for ignition timing, fuel delivery, throttle mapping, load maps, etc. That's just my own guess though.
W211 E55K, Duc 848
Hopefully just a clogged filter as I've never changed it EVER.
W211 E55K, Duc 848
Replaced both fuel pumps and sender unit and the issue went away. One of the harnesses to one of the fuel pumps was completely corroded and barely making a connection.
Good job, interesting that you did not have any misfire codes, how much did you have to pay for the pumps / tank units?
W211 E55K, Duc 848
We were able to narrow it down to that because of the lack of codes... We hooked up a pressure gauge to the fuel line. At idle it held 40Psi, once you hit the throttle it dropped to 10Psi, that was the dead give away it was the fuel pumps/sender unit. Walked out the door with all OEM parts from our local dealer for about $899.
W211 E55K, Duc 848
Here are the two part numbers for the fuel pumps/sender found in our gas tanks under the rear seat located on both passenger and driver side.
211 470 51 94
211 470 17 94
211 470 51 94
211 470 17 94
