Some quick datalog info, opinions?
996 Guards red / 2008 Hayabusa / 2004 E55 AMG
Over the last few days the car has felt ever so slightly down on power (yes I can search, yes I know this MIGHT be an IC pump).
Ambient temp - 70°F
IAT's - 145°F under full throttle but quickly return to the 88-110°F range
Timing was -21 at WOT with occasional spikes of -31
Ambient temp - 70°F
cornfed gtr and m3
need more info but it sounds like your pump is on its way out. What is your current cooling setup? Also, 88-110 is a huge gap. If your iats were 40 over just cruising, definitely the pump is out. DO you have a tune on the car? When you say wot...what speed did you run up to? If you ran up to say 120mph, and your timing fluxuated between 21 and 31 that is a timebomb waiting to explode.
The pulls were 60-100mph, repeated and consistent. The mods are Eurocharged 172mm pulley and box tune, stock cooling.
cornfed gtr and m3
Hmmm. I would try a new pump, but maybe your pulley and tune are too much for stock pump. Might need a HE also.
Can you post a log so we can see what your timing does during a pull?
In that case, I'll get a cm30. As for heat exchangers, which of these two would you recommend?
http://cgi.ebay.com/ebaymotors/Alumi...-Intercooler-/ 190355374159?pt=Motors_Car_Truck_Parts_ Accessories&hash=item2c5210804f http://cgi.ebay.com/ebaymotors/UNIVE...r_Truck_Parts_ Accessories&hash=item2a0df768e5
