Android Torque application.
Rating: Thread Rating: 4 votes, 5.00 average.
Old 03-02-2012, 02:18 PM
  #201
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Originally Posted by black06c230
My dash reads in F and my IAT temp was in F as well. I just replaced a CM30 on it as it was doing a bad job of cooling also.
Maybe swap to an upgraded '10 unit?
Bad CM30 perhaps, they are known to go out. In my testing the '10 and CM30 perform similar with an edge to the '10. The WP136 was considerably higher.
Bleed system? Kinked hose at the pump?
Old 03-02-2012, 03:23 PM
  #202
ZAHANMA's Avatar
'13 Dodge Dart, '16 Audi Q5
The only thing I would caution people with is trying to log more than one parameter at a time. There has been some discussion about the ELM not being able to read multiple parameters at the same time with any decent refresh rate.
However, it does seem like it is worth it just for clearing any codes that may arise.
Old 03-02-2012, 07:21 PM
  #203
jmb614's Avatar
E55 AMG
I've datalogged both a CM-30 and Wp136, meziere hands down is the better pump. At least on my setup.
Old 03-12-2012, 03:50 AM
  #204
Chris Buffalo's Avatar
2016 E63 s63 (sold),1986 Buick Grand National (sold)2014 ML63
Wow this is cool - Whats the part number for the OBDII - Bluetooth adapter?
I'm all over it!
My HTC EVO just became cool again!
Old 03-12-2012, 11:53 PM
  #205
Found it - ELM 327?
Old 03-13-2012, 12:07 AM
  #206
Ryououki's Avatar
2005 E55 AMG
What should I be seeing for my air intake charge after running it a bit hard? What is too high? Thanks.
Old 04-27-2012, 06:09 PM
  #207
Das Geld 2's Avatar
SL55, S500
Originally Posted by Denroll
This particular app isn't yet available for iPhone, but a quick search of the app store brought me to this DashCommand app:
http://www.palmerperformance.com/pro...hone/index.php
Looks pretty promising:
This part is cool:
The downside is that it's fifty bucks, but since I have a $25 iTunes gift card, I might try it out.
Works pretty cool on the Iphone w/the ELM 327 and ROQYBT from Cydia.
Old 04-27-2012, 10:22 PM
  #208
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
Wow that looks much more sophisticated than our dated torque app lol
Old 05-22-2012, 04:05 AM
  #209
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
What should Throttle % read when the car is idling? Mine is showing 3.9% at idle in gear which doesn't seem right. Do I need to recalibrate my TPS or something? What values are you guys seeing for Throttle %? I'm using the ELM 327 with Torque on a Droid RAZR.
Old 05-22-2012, 04:38 PM
  #210
Robert AMG's Avatar
Cls63 & C32
For those with android you can download from google the "blackmart alpha" software, with this app you can download any paid app for free (cracked), the dashcommand is included
Old 07-03-2012, 10:45 AM
  #211
chawkins2001's Avatar
2006 E55 AMG
Is anyone using the A/F ratio reading through TORQUE. If so, how did you set it up with the o2 sensor, and what cable are you using for the sensor to phone connection?
Old 07-03-2012, 08:15 PM
  #212
jmb614's Avatar
E55 AMG
To my knowledge there isn't a way to pipe a widebands signal into torque. That's the reason I got a dashdaq with my zeitronix.
I remember seeing a post from AMGFan a while back where he had a really sweet looking software/hardware setup that was aesthetically better than the dashdaq but can't remember the name of it.
Old 12-26-2012, 12:56 AM
  #213
bnzuovr's Avatar
2004 W211 E55K, GL550
lookin to buy a elm 327 but does anyone know if this works with dashcommand even if it shows it it compatible with TORQUE.
Old 05-10-2013, 01:55 PM
  #214
gazosnic's Avatar
e46 m3, w211 e55
Just got a new andriod phone so got this running. What IATs would you say are normal? I did a few quick runs today and mine were showing low 90's and high 80's when its only 46 degrees out.
Thoughts?
Old 05-20-2013, 08:44 AM
  #215
marc.l's Avatar
2003 E55 estate
Hi guys
Just started using dash command via wifi adaptor , and I have a few questions
Is the MAP value actual or calculated ? And what value should I see on a standard car ?
Marc
Old 05-21-2013, 11:40 AM
  #216
jnash's Avatar
2017 S63
Originally Posted by marc.l
Hi guys
Marc
Hey, can you share your Wi-Fi settings in DashCommand for me? I have an Wi-Fi adapter but could never get it to communicate only via the Elm BT adapter. I have a Nexus 7 tablet.
Old 05-22-2013, 12:33 PM
  #217
Moedy's Avatar
'05 CLK55, '04 CLK320
There is two versions of the ELM. One is bluetooth and one is wifi
Old 05-22-2013, 02:45 PM
  #218
jnash's Avatar
2017 S63
Agreed. I have the two adaptors both a BT and a Wi-Fi version. I can connect successfully with the BT Elm adapter but wanted to try and connect the Dashcommand with the Wi-Fi version. So, can you please share the settings you are using with the Wi-Fi version?
thanks
Old 05-22-2013, 11:10 PM
  #219
edan82's Avatar
2003 E55 AMG
i tried some of the Ebay link posted in the thread but most of them already ended sells.
can someone please post a link for the OBD bluetooth device which already tested and is working good ? (my car is 03' E55).
thanks guys!
Old 05-31-2014, 02:53 PM
  #220
gaiex's Avatar
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
Any one had managed to get the following readings with the torque app?
- Ambient temperature
- Engine oil temperature
- Current Gear
- Injection Quantity
- Oil pressure
With torque pro I can get everything I need including AFR and trans oil temp, but except the above ones, that would made this tool perfect!
Old 05-31-2014, 03:29 PM
  #221
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I'd like to get a trans. temp reading...
Old 05-31-2014, 06:42 PM
  #222
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
My understanding of this is the trans communicates in a different protocol so it might not be easy to get an app that can handle this....?
It would be fantastic if one could though anybody know? As id be all over this if i can get trans temp as i have an aftermarket cooler.
EDIT: looks like gaiex has trans temp working on torque pro.
Old 05-31-2014, 06:47 PM
  #223
austingtir's Avatar
Oil pressure
Oil temp
Trans oil temp
Which app can do those and is it possible?
Old 05-31-2014, 08:19 PM
  #224
gaiex's Avatar
I have trans temp reading very accurate, as is the same sensor that my SDS4 reads as I have checked.
In torque pro you can load the predefined set of PIDs from "Chrysler/dodge/Jeep/Mercedes" in the options on "manage extra PIDs/sensors"
The correct PID depending the car will be:
"transmission temp (jeep pre 2012)"
"transmission temp (jeep 2012 and later)"
"transmission temp (crysler/dodge)"
or loading "others" predifened set:
"transmission temperature (method 3"
Now for a good data logging and better ECU tune I'm missing:
- Current Gear
- Oil pressure
(also add/change the 80-120kph to 100-200kph time if possible)
I found this information but I'm not a geek for this:
http://torque-bhp.com/wiki/PIDs
http://torquebhp.wikia.com/wiki/How_..._extended_PIDs
http://www.outilsobdfacile.com/obd-mode-pid.php
http://torqueloganalyzer.blogspot.pt...on-torque.html
Any geek out there that can understand how these PIDs thing works and search for the PID's we really need?
PS: I currently have on my 2008 CLK320CDI:
-rpm
-speed (gps and OBD)
-accelerator / load
-MAF
-Fuel rail pressure
-O2
-AFR
-Intake pressure
-CAT temp sensor 1
-CAT temp sensor 2
-Intake temp
-Coolant temp
-Trans fluid temp
and some more I don't use
Old 10-16-2014, 01:25 AM
  #225
mrweelr's Avatar
What TPS % are you guys seeing at WOT? If I push the pedal to the floor, I'm seeing a max of 96.5 % in Torque. Should it be 100% and could I have a bad or miscalibrated TPS sensor? Want to be sure I'm not leaving power on the table.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: Android Torque application.
