what is a good size rear wheel for a drag radial?
Subscribe
Feb 17, 2011 | 01:25 PM
Hey Guys,
I've been trying to find what is a good size rear wheel for mounting a drag radial on.
When I search, I get all new wheels, and larger diameters like 19's & 20's
I’m pretty sure you can fit a 17 inch, but can you run a 16, or even a 15. the more sidewall on the drag radial the better.
So I guess my question I what is the smallest diameter wheel that will fit over the brakes on the W211?
What is the largest width, and correct offset?
Does anybody have a wheel that they have used, and would recomend?
Thanks in advance, Bob
Reply 0
Feb 17, 2011 | 01:29 PM
I run an FK Wheels 17 x 10 with 20mm spacers. I have 275/45/17 hoosier on there. I know some guys fit 16"'s but on my setup I have maybe 3mm clearance to the caliper. Partly do to the style wheels I have.
Reply 0
Feb 17, 2011 | 02:43 PM
I believe the smallest you can run in the rear is a 16" wheel.. Many have done it and if you search you should find some information..
Reply 0
Feb 17, 2011 | 04:28 PM
Quote: I run an FK Wheels 17 x 10 with 20mm spacers. I have 275/45/17 hoosier on there. I know some guys fit 16"'s but on my setup I have maybe 3mm clearance to the caliper. Partly do to the style wheels I have.
Your car makes me mad, It should be a lot faster...
Reply 0
Feb 17, 2011 | 04:31 PM
I ran 16s, no way a 15 will fit.
Reply 0
Feb 17, 2011 | 06:20 PM
Quote: Your car makes me mad, It should be a lot faster...
My 11.7 was in sept in 85 degree weather(heat soaked 110's IAT in the staging lanes) before the 82mm tb, airboxes, with a crappy old tune that didn't have torque limiters removed. Had a huge delay between 2-3 shift. It will be much much faster this spring...
Reply 0
Feb 17, 2011 | 06:24 PM
Quote: My 11.7 was in sept in 85 degree weather(heat soaked 110's IAT in the staging lanes) before the 82mm tb, airboxes, with a crappy old tune that didn't have torque limiters removed. Had a huge delay between 2-3 shift. It will be much much faster this spring...
I hope so! Your mods and times make me cringe every time I see your sig
Reply 0
Feb 17, 2011 | 10:52 PM
16's awesome.
How about width? 9? 9.5? 10?
Reply 0
Explore
Subscribe
Currently Active Users (1)
