How much the car be lower with STAR?
Old 03-02-2011, 10:54 PM
m3pj's Avatar
04 e55 amg
let me know if you found 1. Im from chicago also
Originally Posted by windycity1
Anyone know where I can get this done in IL? Thanks.
Old 03-03-2011, 07:22 AM
saleen01's Avatar
2004 E55
anyone in Toronto, do STAR lowering?
Old 03-03-2011, 11:28 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by BenzoBoi
If you lower your vehicle with star 3/4", when you press the raise button, it will go probably go back up to around stock height. Hope this answers your question.
Not too good for me as I have a steep angle into the driveway and I clear by about 1/2" when the vehicle is raised to the maximum. Might try a LoMo lowering module which apparently can be set to stock setting when required.
Old 03-03-2011, 11:47 AM
saleen01's Avatar
2004 E55
wow, so you are confirming that STAR lowering once done, does not allow you to go to the highest possibly setting in comfort?
Old 03-03-2011, 12:34 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Ive heard once lowered with star, that is your new "stock height".. So in comfort it will only adjust up a bit from your new lowered height.. There is no way to go back to stock height unless you adjust it on star again.
Old 03-06-2011, 11:30 AM
GreyStorm1499's Avatar
E-Six-Three
Would lowering with STAR cause any premature AIRMATIC failures ?
Old 03-06-2011, 11:39 AM
  #32
jayhawkblk's Avatar
2012 Armada
No more than any other method.
Old 03-06-2011, 12:30 PM
  #33
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Yep, STAR resets what your car knows as "stock" height. The only way to return to actual mercedes stock height is to hook back up to STAR and redo everything. That is why the ELM is the best solution. On my Renntech V2, there is a setting for stock height. You hit that and it goes back to the origianal MB preset stock height. That is why I always say the ELM is the real only good solution to lowering these cars.
Old 03-06-2011, 01:15 PM
  #34
AWOL's Avatar
e55
If star by itself isnt low enough, just throw in some washers
Old 03-06-2011, 02:24 PM
  #35
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Anyone with STAR in Houston willing to do lowering & -10?
Quick Reply: How much the car be lower with STAR?
