air box mod
Old Mar 17, 2011 | 07:25 AM
  #76
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
here go some claims from the RPI scoops that are a piece of Aluminum you added after modifying the intake baffles . Do they help getting more air in the car ???? 1000% , how do i know??? After install i was at the track and after a pass i got a Camshaft error reading due to too much air going in and not enough flowing out from the exhaust side hence why i did the cat delete afterwards and added 3 inch pipes .
RPi Ram Air Induction Kit - E63 AMG
One of the major issues with the E63 is the lack of intake air volume available to the engine during hard acceleration. RPi's Ram Air Scoops converts your factory intake system into a ram air type. Other aftermarket induction kits mostly suck in hot air causing a loss of performance. The use of heatshields are not very affective as heat shields mainly work to block radiant heat. Utilizing the stock intake boxes, expect a 10whp and 11wtq gain with 70mph airflow. RPi's Ram Air systems have been dyno proven as well as track proven and come with a 30-day money back guarantee.
Old Mar 17, 2011 | 07:32 AM
  #77
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Originally Posted by buckeyewalt
I'm going to interrupt the dart throwing here and ask a question that was not answered,,,,,, would the addition of the scoops on a tuned car throw out any codes???
Yes they will , At least they did on my car . too much air flow and not enough exhaust flow gave me a camshaft error reading on exhaust side .
Pretty much the car was saying "delete my cats you big dummy "
Old Apr 12, 2011 | 03:08 PM
  #78
munich55's Avatar
E55 AMG W210 - sold, E55 AMG W211 - sold, CLS 500 C219 - sold, E63S AMG W212 - sold, C63S AMG A205
Please can somebody tell me the partnumber of the S55-Pipe?!
Thx
Old Apr 13, 2011 | 03:20 PM
  #79
TonyGia's Avatar
W211 P030 E63 AMG // W204 C63 Coupe
From reading I'm about to go take a look under the hood
Im interested in doing this as a start for engine work on the 63, you are very limited to what you can do while the car is still under warranty.
So at the end of the day who makes a better product for the money? RPi or TTM? and why?
Old Apr 13, 2011 | 04:24 PM
  #80
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
the RPI item is only a piece of aluminum that you zip screw into the modded air baffle and the TTM scoop is a welded scoop or baffle and by far the better built item
Old Apr 14, 2011 | 08:17 AM
  #81
munich55's Avatar
Can somebody help me?
My Dealer can't find without VIN.
Is the partnumber for S55-Pipe A113 094 1282 ???
Thx
Old Apr 14, 2011 | 09:48 AM
  #82
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
That's pretty pathetic.
Here's a VIN from a random '05 S55 on AutoTrader:
WDBNG74J35A446835
Old Apr 14, 2011 | 02:40 PM
  #83
TonyGia's Avatar
Okay so TTM it is!
Now from this point will it throw codes for too much air? Remember you saying something about removing your cats.. My exhaust just has a resonator delete done.
Old Apr 14, 2011 | 08:36 PM
  #84
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Okay so TTM it is!
trial and error will tell . I also had the CArbonio airbox with the BMC air filters at the time . If so delete the cats and put the resonator back on , it will sound alot better .
resonator removals do sound a lil mustangish to me
Old Apr 15, 2011 | 02:48 AM
  #85
munich55's Avatar
Thx a lot.
The right partnumber is:
A113 094 1282
Old Apr 15, 2011 | 04:09 PM
  #86
munich55's Avatar
Installed right now.
But it wont fit exactly on the Airboxintake.
Is there something to do?
Old Apr 16, 2011 | 02:15 AM
  #87
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
I just took mine off, good idea, I also shaved a small amount of the rubber wings. I did notice that my right tube is not fitting over my intake, so I had to reform it and get it back on, it was hanging half on? I am talking about the end that is closest to the radiator.
Old Feb 1, 2012 | 01:14 AM
  #88
Toadster's Avatar
2005 E55 AMG
Originally Posted by ertech
Why would they design it that way?
reduced air inlet noise - its' a Merc, not a Mustang...
Old Feb 1, 2012 | 11:04 AM
  #89
GregMB's Avatar
There's one member here who would disagree with you.
(hint: it's not me)
-G
Old Feb 1, 2012 | 08:11 PM
  #90
E55W's Avatar
E55
what about a larger Y-pipe
