e55 top speed 140mph?
has anyone else encountered this?
https://mbworld.org/forums/w211-amg/...top-speed.html
But to answer you - its 155mph from the factory -- but it can be off 5mph --
So, yours is not normal --
Brgds
Brgds
Hope this helps.
is that an option i can change in the user controls or is it something in star command that i need a tuner to change?
I am planning on going kleemann stage 2 or eurocharged stage 2 soon (havent decided yet) but i assume their software would fix this?
i know what the theoretical top speed is gearing limited and i know the technical 155mph electronic speed limiting...
i dont know why mine stops at 140mph ... and its not ic pump because its not like i llost any power as it held strong at 140mph with plenty RPMS left... even without a supercharger the power of the engine alone should carry this car past 140mph so i was thinking maybe certain cars had different electronic limits, but couldnt find any post on it
Enjoy
"Winter mode was replaced by comfort mode on all 2003 mercedes models. It is essentially the same feature, only the name is different."
and my car always has the "S" button pushed so i wasnt in "C" mode... so i am at a loss again why my car limited at 140mph
[Nothing in "Engineering Mode"]
Switch off the Winter Tires all-together.
This has nothing to do with the "S", "C", or "M" button on your gear shifter at all.
