Project ported heads coming soon!
PLATINUM SPONSOR
After a year of R&D , in my spare time, I hope to have my ported heads on soon. Good flow gains were attained and most of at LOW lift and high lift vale events! Spring pressure was also increased 10% to help handle higher RPM. My stock cam lift is only .420 lift range but still going to see 330 CFM in that range and that is more than most of the modern American CNC muscle heads can attain.. Very cool and can`t wait..
My header project was a big one, so was the idler pulley set R&D and of course the huge fuel injector /fuel pump project to handle power increases. Texas mile is this weekend but could not get the heads completed by then.. Great news though, they are having 3 events this year! Next on is in may.. Would like to see 190 mph next time..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2003 E55 & 2014 GL550
Was watching a top fuel show last night and they were mentioning how they used gorilla size intake valves to get as much air in as possible on the in stroke. Wish I went bigger intake valves on my head job. Just port and polish/angle valve job over here and wasnt too big a difference. ** Edit, I was in the middle of "finding a dyno guy hell" at that point and couldn't get it over to the dyno so who knows what gains I had.
Good luck Brooke!! You are still the modding mad man!!
PLATINUM SPONSOR
I saw the VRP heads on a fully moded E55 (top mounts and all) and it was a disgrace what it did to the torque and low end power.. I dynoed the same day and made more TQ than that car. That was before my headers and latest tune.. Those heads tipped me off that we need to move carefully to un-lock the power and not go backwards. The flow gains are there and across the lift band, next for install and test. If I can get enough power, will go for a ten second ET in the summer heat.. Be nice to run 10`s all year in Texas on a full weight CL55 in street trim.
Thanks Grant, thinking 200mm though..
__________________
www.ultimatepd.com
www.ultimatepd.com
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
PLATINUM SPONSOR
Ok, here are some pics.
Underside of head
Intake side showing both 1.5" intake valves. Intake side is left a little rougher to help with fuel atomization.
Exhaust port (super polished)
Top view of head. Spring pressure was increased by 10%
Stay tuned for the next large HP increase project!!! Will be starting soon! No, it is not nitrous either..
Underside of head
__________________
www.ultimatepd.com
www.ultimatepd.com
just liked the page, looks incredible! what's the down time on this sort of project? great work guys
Looks amazing Brooke can't wait!
Hey so what fuel pump did you end up using? I haven't upgraded my fuel pump yet and would love to since I already have my 550 Injectors and converted my fuel rail to a full return system!
We do share the same fuel system
PLATINUM SPONSOR
AMG_RL just liked the page, looks incredible! what's the down time on this sort of project? great work guys
ShangoAshe Looks amazing Brooke can't wait!
__________________
www.ultimatepd.com
www.ultimatepd.com
