Diffuser installed, pics
Old Mar 26, 2011 | 09:51 AM
wsybert's Avatar
'20 GLE350, '21 F150 Raptor, '03 BMW M3, '22 KTM 890 ADV, '23 Triumph Trident 660
Ordered it from JBSpeed. As always, great service and quick shipping. Took a little over a week.
Quality is a little hit and miss on other parts I have ordered from them, nothing too bad, and worth the money for sure. The diffuser was pretty good. The only issue I had was on the right side, where it wraps down around the tips. The curve is a little off. Nothing I couldn't deal with though. Other than that, the quality is very good. From what I can tell, the part is fiberglass with a carbon fiber overlay on the side you see. Came packaged well and no damage when I received it. Pretty light too.
On to the install...So I pulled the plastic trim off of the bumper using a heat gun and a plastic scraper. Found that from searching on here. Took about 10 minutes. Don't plan on keeping it. It came off in pieces... even though I tried to salvage it. Removed all the two sided tape and cleaned the bumper with some prep solvent, to remove any oil and wax.
I fastened the diffuser from behind with ten #10 stainless sheet metal screws, 5/8" long. I drilled the holes in the bumper slightly larger than the screw diameter. Three across the top, three across the bottom, and two on either end, where it wraps down around the side. I put the diffuser up against the bumper and got it aligned where I wanted it, then marked one of the holes with a marker, from the back. I drilled the marked hole in the diffuser with a drill slightly smaller that the #10 screws I was using, and test fit it. Once I liked the location, I installed that one screw and then worked to mark the rest of the holes, then drilled them.
After I had all the holes drilled in the diffuser, I used a black polyurethane sealant as an adhesive. It is made for roofing applications for flashing and shingles. Flexible and good in the weather. Installed the screws and that was it.
Pretty straighforward, just take your time and "measure twice, drill once".
Unless someone rear ends me, it's not going anywhere. Total install took about 2 hours. Should have taken pics along the way, forgot.
I like the look a lot, plus it frames in the tips and helps with how they were sticking out more than I liked.
Bill
Attached Thumbnails Diffuser installed, pics-diffuser1.jpg   Diffuser installed, pics-diffuser2.jpg
Old Mar 26, 2011 | 02:58 PM
tbal's Avatar
Haters crazy
Looks good!
Old Mar 26, 2011 | 04:23 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Looks good! Do you recall the name of the black polyurethane sealant you used?
Old Mar 26, 2011 | 05:36 PM
wsybert's Avatar
Thanks. It's made by DAP, Premium Roof and Flashing Sealant.
Old Mar 26, 2011 | 06:03 PM
03'55AMG's Avatar
AMG
Nice tips! Looks very aggressive
Old Mar 26, 2011 | 06:04 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Looks ok, Kinda bulky, The Euro Teck ones slid in perfect..
Old Mar 26, 2011 | 11:03 PM
baldmike73's Avatar
looks good - is it just me or is the right side tip a bit off?
Old Mar 27, 2011 | 12:02 AM
wsybert's Avatar
A little. I fixed that today. It actually got worse after I drove it and everything settled. I had to tweak the hangers on both mufflers to get it perfect.
Old Mar 27, 2011 | 07:01 PM
baldmike73's Avatar
what wheels are you running? post a pic or 2
Old Mar 27, 2011 | 09:23 PM
wsybert's Avatar
I believe they are Avant Garde M333, which I think is a CL rep wheel.
They came on the car. Link HERE.
Old Mar 27, 2011 | 09:39 PM
03'55AMG's Avatar
AMG
the pics are dead
