Now I'm officially depressed...
2005 E55 AMG
After countless hours fixing the woodruff key ( the keyway was in great shape but took forever to get the timing cover off and what not ) and making the crank snout look like new, today I installed my brand new 180mm pulley ( which Eurocharged kindly replaced free of charge after the first meltdown ) and torqued it with my BRAND NEW torque wrench.
Well guess what? After ONE wot pull my pulley let loose again, this time it didn't come out completely...it just started to slip badly on the crank ( enough for my engine to fall flat on it's face ) and it started to wobble badly ( it had no wobble when installed ). Now I can't even take the pulley off...it feels like it's welded on.
I'm not sure what to do now....I'm truly depressed now.
Oh man. Keep your chin up still, I usually tend to get angry and start swearing and kicking the tires lol. You'll need a pulley puller tool you can rent one from auto zone. I wish you luck my friend
c200k
I wouldn't recommend that for this poster. It's sad to say it direct, but the car is better left with a professional. Seeing your recommendation, I'm running through the list of FAIL the OP will inevitably go through with a puller.
With all do respect to Mr. sknight. Your posts remind of when my childhood dog died and all my mother could say was: well it was just a dog. While there may have been truth in her statement, it was far from being a kind thing to say.
2005 E55 AMG
I told you so. I voted that you button it back up with the stock crank pulley, so maybe after the umpteenth failure in a row, you'll get the idea.
YOU may have told me to use the oem pulley again....but 78% of the forum users told me to go with the 180mm pulley again according to the thread you just posted at just to rub it in my face.
c200k
So steering you in the right direction from the beginning is being a "hater"? I saw warning signs right from the beginning that you didn't identify even after the initial damage, despite writing about them. Then you wanted to install the pulley without the key. Now you've reinstalled it with more problems. After a while you're outclassed. Take it to a professional before more damage is done, but I'm fearing we already have some significant damage.
And no, my parents didn't abuse me. They taught me to be realistic and they taught me that I shouldn't be so sensitive because the world is a harsh place and lots of people are not sensitive and toughening up is a good thing, especially when I identify anything that is not sensitive enough for me as wanting to be coddled by a stranger.
My advice: GO TO A SHOP. USE THE STOCK PULLEY.
E55
We took one off today and it required an unreal amount of torque. We placed a longer bolt in the torque converter to lock things and used a 5' breaker bar to finally break it loose.
Regards,
Todd
Regards,
Todd
Why didn't you go to a shop in the first place?
E55
Did the key break off again? I guess it did if the bolt is still torqued and it is spinning on the snout... Surprised this would happen a 2nd time unless there is more damage that you didn't find the first go around.
c200k
That's my suspicion, and he needs a mechanic and people here to back that idea up, not complain about how I need to come down to his level of sensitivity.
The only way to help the OP is to convince him that the car NEEDS to go to a professional. He will devise "Crazy" plans along the way, as he indicated in the first thread, which will only lend itself to a system by system destruction of the car.
Please tell me you bought a new bolt. If you reused the old one it wont hold. And that was a question as well as a statement you might already know.
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
yeah - I 2nd that --
Did you use a new bolt? You mentioned a new bolt wrench --
It seems like common sense after your 1st failure but thought i would ask --
1 Post
SRT-6
I'm depressed too! With 2 failures in a row I think something is being unknowingly done wrong. Some reflection should be the first action, then get it apart again. My guess would be that for some reason neither pulley was all the way on. It's the only logical answer as to why the key didn't hold or was being asked to to what it's not supposed to do.
Les
Les
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
I would suggest a totally fresh look at this. First, is this the right pulley? Second, is this the right key? Third, is there any damage to either? Fourth, is there any damage to the keyway on the crank? You might need micrometers to take measurements. Don't panic, even if the worst case scenario manifests - and the crank is damaged - it can still usually be repaired.
Once all items are certified serviceable you should be able to re-assemble without difficulty but do ensure the key fits properly.
Chin up, friend...!
Brgds
Chin up, friend...!
Brgds
2004 S55 (SOLD, miss it every day), 2009 GL550
i feel bad for you, sknight. you told it like it was, but the OP didn't listen and ended up in the same boat again, if not worse. now, you do it again, and you get bashed. that ain't right!
truth is truth, whether it's blunt truth or not.
c200k
However, I do like the end solution of watching the destruction. If all else fails.
c200k
Yeah, that's for me to put up with. No one else's concern. I know how it makes me "e-appear". However, it's still telling that the thread has not produced such strong responses towards the OP, who is destroying his car, against advice.
another question -- Are you using a longer belt? Did you change the water pump pulley?
