W211 E55 0-60 performance figures
Old May 15, 2003 | 07:32 AM
stephens's Avatar
E55, F550, S600 Ducati 999
I took the car out for a quick spin this evening with a GTech Pro attached.
Since it has only done 1200km's, I kept revs under 5500rpm and the road was damp.
After the weekend The car will have done over the 1500km break in distance, so I will give it another run and also get 1/4 mile figures. I use a section of a local freeway at night which is both straight and flat.
I got a 4.71 and 4.84 sec 0-100kmh. This equates to approx 4.5-4.6 sec 0-60mph. These equal the manufacturers performance figures.
I feel sure that given its head and a dry road, it will easily do sub 4.5's 0-100kmh.
A set of Pirelli PZero's will be fitted tomorrow (the tyres on my other E55 need replacing, so I am using the opportunity to fit the E55K tyres to the old car and fit stickier, wider tyres on the new one.)
I am quietly confident of a 4.2-4.3, which is the same as 4.0 0-60mph.
Old May 15, 2003 | 10:39 AM
RS-Kicker's Avatar
SL230 -64 Pagoda
Any figures for 402 meters?
G-Tech is as you may know a not wonder of accuracy.
I usually add about 0.5 secs on the 0 - 100 km/h time and a little less on the quarter mile times.
Good luck!
Old May 15, 2003 | 02:12 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Stephens, are you going with stock 245/40/18 up front and wider 275/35/18 in rear or something else? Thanks.
Old May 15, 2003 | 04:01 PM
stephens's Avatar
E55Kev
Unfortunately the standard rims limit you to 245 and 275 tyres.
If I change rims at a later stage I would go to 255's and 285's.
RS Kicker
I have has the GTech for quite some time now and have calibrated it on a dragstrip, against stop watch and speedo (when the Gtach says you have reached 100kmh it is exactly accurate with the speedo) and have not experienced the same variation you talk about.
An Australian performance car magazine used one last year to compare the E55 with a HSV Holden on a drag strip. They commented on how surprised they were at the accuracy and consistency of the unit.
My experience has shown as long as the road is truly flat and straight, the unit is accurate.
Old May 16, 2003 | 08:16 AM
03E55AMG's Avatar
Porsche Twin Turbo, Supra Turbo, EVO Turbo
The New Gtech I was surprised because of its close accouracy, it is VERY close except for the MPH that is around 2 mph off. I tried it with my M3 and I was getting 13.2-13.3 @108-107 when they usually trap around 105. 0-60 I was getting 4.8-4.9 So It's not that off, at least the new one that is.
Old May 16, 2003 | 11:55 PM
pocholin's Avatar
Volvo V90 CC
Those are sweet 0-60 times, I'll be sure to keep checking this thread to see 1/4 mile results.
Old May 17, 2003 | 02:31 AM
stephens's Avatar
In the current Road and Track they got a 4.2 0-60mph and a 12.4 1/4 mile, so my goal isn't unrealistic.
