larger then 180MM pulley?
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Source:
https://mbworld.org/forums/w211-amg/...ize-boost.html
Source:
www.ultimatepd.com
I'm more for working with the boost level I have. With that said... Finding a way to cool the boost down that you already have, will probably give you better results.
I think someone is also running a 210mm in the middle east also.
but the car is unbleivable fast.
i wish there is a way to increase the volume of air wthout this method. why no one made bigger S/C for this car.
Im hitting the dyno today so maybe I picked up some from the retune.
