raced 996 TT
We raced and it was basically too close to call -- 60mph to 4th gear
and 40ish to 4th gear.... Stopped shortly after 4th was engaged.
MY gears are longer and was able to pull at those moments -- but he would inch back slowly-- basically neck and neck the whole time...
He was impressed by my +4200lb beast 'pano'. His car is like 800-1000lbs lighter. He said my car pulls hard in 4th.
My guess is my car is around 600 crank HP -- its pretty strong for the little mods -- racing my friend's E55 with more mods , 180 - LTs - 82mm TB - no cats... he can barely pull on me.
Anyways - who really cares about the numbers -- too many variables as we all know -- but a good race.
what do you think? that TT 996 must be around 500 crank HP?
but as you know dynos vary, so would have to dyno at the same place he did toget an idea,but even then depends on the weather in which he did it also
Never raced ours, but all the tests show the quarter -- stock to stock -- would be a driver's race. He's not stock.
Mod the 996TT and its lights out... especially if you go into the higher stages.
Heiss damn those curb weights for the 996 seem low
I thought it was closer to 3300 lbs? I know my 997TT is around 3600 lbs.To the OP, sweet race!!!
Next month - He will have his new shop running -- and we will probably do some dyno pulls.
