Boost loss due to L/t
Tom
Tom
But what do you know....you're buying a bimmer. LOSER.
Tom
The S/C is mechanically driven, the ratio of S/C rpm to engine rpm is fixed by their respective pullies and ratio. So, while the S/C is spinning at the same rpm (for a given engine rpm) both pre and post LT, since the amount of post-S/C restriction has gone down post LT install, it (the S/C) doesn't have to fight as hard to reach that same rpm. So, arguably, it isn't working quite as hard... and, as mentioned earlier, heat-generation drops as well.
As for the part about the S/C working harder to hit the same boost... this isn't a turbo motor - the S/C isn't trying to hit any specifc boost target. The S/C won't hit the same boost, because, again, it's mechanically driven and those ratios are set (unless you change the crank pulley, S/C pulley, or both).
Boost goes down because restrictions/bottlenecks have been mitigated. CFM, however, doesn't... that's the key.
The first part is debateable, IMHO. The second part is wrong.
The blower has worked just as hard and like you said its mechanically driven.
You are confusing that boost psi is the cause of heat when its all about the rpms of the supercharger spinning that causes the heat.
run a 220mm pulley and no headers at all on your car,the boost in the manifold will be about the same as stock boost but the blower will be 10,000 rpms over its limit and melt down with one 1/4 run
A supercharger efficiency map is made up of rpms and volume flow for a specific psi
heat/boost will be the same at a givin rpm,they dont tell you you need xyz headers on the car when reading it.
It would be silly to say to someone that going from a 168 pulley to a 180 with long tubes will lower there intake air temps.
ps the supercharger gets a break when you free up the intake path with no restrictions like the use of say a carbon air box with filters
Tom
Tom
Id like to read up on how the temps will drop and see where you are coming from.
think of it this way,the blower made the same psi.1.5 lbs off boost snuck by the chamber and out the tail pipe.The boost was made at one point or another.You can play with cams to get that lost boost back in the mid range but suffer top end power.
That is why your a/f gets leaner with headers,the tail sniffer is seeing more air that got blown by without burning.
Tom
Headers reduce boost and make more power by flowing air more efficiently than the stock exhaust manifolds. An engine is an air pump. The faster you can get air in and out the more power you will make. If you can make the heads flow more efficiently, the engine will make more power and there will be less boost. Boost is the measure of an engines inability to flow air from forced induction.
Eloquently stated, thank you.
