BEST e55 AFTERMARKET EXHAUST
http://www.youtube.com/watch?v=isJRdjNlbKI
A very close second:
http://www.youtube.com/watch?v=-qbQcsYAIMM
I am wondering if I should take stage 2 renntech with carbon air box... instead of stage 3 withouth air box but with headers... and get specialty headers from either supersprint or bhm.
also between supersprint and eiseinmenn which is the loudest...
No mufflers?! Isnt that going to be bad for my car in the long run...
All Eisenmann systems are handmade in Germany-
http://eisenmannblog.com/2011/04/08/ind-eisenmann-tour/
Mine fit the same way on an otherwise stock exhaust system. A simple adjustable mounting bracket would let the tips be aligned correctly, but their mount is simply a non-adjustable bent steel rod that slides into the rubber hanger. When you drop nearly $3K on exhaust, it ought to fit right without the need for modification. Between the misalignment of the tips and the constant drone in the cabin (race version with factory exhaust intact), it was an easy decision to sell them.
