Alusil or nikasil ??
http://www.marcusfitzhugh.com/CLK/DIY/rebuildable.html
To Nikasil coat a sleeve, an aluminum sleeve is dipped in an electrolytic bath of nickel, silicon and other metals for about an hour. The electrolytic reaction causes a silicon-nickle coating to adhere to the aluminum surfaces. When finished, the aluminum sleeve has a Nikasil coating. This makes it pretty obvious that M112/M113 sleeves are not Nikasil. The Mercedes-Benz press release said the sleeves were 'silicon aluminum'. It didn't state that they were nickel and silicon coated aluminum.
Mahle is the supplier of Mercedes-Benz sleeves. It's well known that Mahle produces Alusil sleeves. Alusil is a high-silicon content aluminum alloy and has been in use for almost 100 years. To make an Alusil sleeve, a high-silicon content aluminum alloy sleeve is dipped in an acidic bath. The acidic bath etches away the aluminum on the outer surface, exposing a very hard, very long-wearing, silicon surface. The finished product is still a silicon aluminum alloy.
And yes, they are correct.
I believe that this is who manufacture the block on the M113 and Porsche V8's, Here some links
http://www.kspg-ag.de/pdfdoc/kspg_pr...rsche_V8_e.pdf
http://www.kspg-ag.de/index.php?fid=105&lang=3
Hope Brooke chimes in (Exotic-metal55). He has more knowledge on this than most of us. One of the few guys running different pistons in the beast.
Lemme PM him and see if he can come on and fill us in .
Cheers _PTEngineering
I agree, our blocks have a sleeve as Patrick/Jim mentioned but not the press in type sleeve that many may imagine. It seems to be cast into the block but I do not have the detials on that. My older threads about re-sleeving had to do with machining out the midddle of the block and dropping in a Siamese style steel sleeve kit from Darton. We do have an alumisil coating but my piston walls were bored out and then re-coated with Nickasil to stock bore specs. This is a nickle carbide style coating and very, very hard! After a lot of re-search, I prefer this coating over a alusil. I think AMG is now using some version of Nickasil, BMW and the Zr1 vette too. I had to use steel rings with the nickasil coating and alusil uses a different ring material.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
