My Braille B2015 Battery
2003 porsche 996 turbo
terminals come with the battery. from my experience unless the car is driven daily it needs a trickle charger. my 32 calls for 74 amp hr battery. the shuriken much like the braille run around 20 amp hrs. so if the sits for a week or more like mine does the static drain will kill the battery. 28$ trickle charger from schumacher and the battery never failed. ill have it at timmayfest if anyone wants to see it
http://www.sonicelectronix.com/item_...N-SK-BT20.html
they also sell the terminals on there for $11.
#32
#33
Came in today. Put it in, car had trouble starting at first. Fired up on 3rd attempt, drove around - no signs of trouble yet. Ill report back with total car weigh in.
I dropped 39lbs from my duralast to the new one
#34
Car weighs in at 3960 with 1/4 tank.
Car takes a bit to crank over on start up. I have it on the trickle charger but Im thinking this is only for race use, not very trustworthy as a daily.
#36
can you record a video?
I might make the switch. I mean, mine starts, but its a tad sluggish turning over for maybe 1 second. When its fully running, I have no issues.
edit: took it off the trickle and it seems to be a little better.
http://www.youtube.com/watch?v=BLfLBHWYycw
#38
2005 E55 AMG
#39
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
First start in the morning. Didnot hook up the tender in for the past 3 days. Have been driving about 10 miles per day.
http://www.youtube.com/watch?v=QXQ7n...el_video_title
#40
I also bought the Shuriken like AWOL in hopes of racing at TimmayFest, but since I am missing that opportunity, if anyone wants it, I will get it to you what I paid shipped, $100 shipped with terminals.
AWOL, you still have boths cats and the resonator in place? I know you did a muffler delete
#41
All cats in place, no resonator or muffs
Word to the wise, go with the braille. The shuriken doesnt seem up to the task for daily activities. I will use it for race use only. Shardul's definitely has more juice on start up
#42
whats the cca for the oem battery? my shuriken bt20 is rated at 850 cca and starts my car fine. granted i have to run a trickle charger due to the low amp hrs, but knew that going in
#43
The duralast has a cold cranking amp of 760, with 960 at 32 degrees and a reserve capacity of 100.
I checked the voltage. While running, its showing a steady 14.0, but during cranking, I saw it dip in the 9's.
#44
My Shuriken showed up today and is a little different to Awols. I got it from Needswings and it came with terminals and mounting surface gear, white tape is just stickers:
#46
#47
shuriken bt20 is rated at 850 CA, NOT CCA.
I have a braille B2015 in my harley.. It has 425CCA.
#49
