Pins behind the washer on the supercharger clutch bolt
Old Jun 2, 2011 | 11:07 PM
gaymg's Avatar
e55
I tried searching and nothing came up about these pins.
Are these guidance pins?
what are they here for?
If they snapped what do i need to do?
Please only answer if you have good advice.
Old Jun 3, 2011 | 01:03 AM
benz_addict's Avatar
V12TT
Dude are you talking about the shims??? They are there for proper clutch engagement... You should replace them unfortunately they only come with a brand new clutch assembly from the dealership and you cannot get them separately.
Old Jun 3, 2011 | 03:14 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Two pins for guidance. When I swapped out a buddies pulley, we noticed his were missing (sheared) , but did not cause any issues.
Old Jun 3, 2011 | 02:04 PM
gaymg's Avatar
e55
thank-you for the quick reply.
I just want to triple check, i read that the bolt is to be torqued to 60nm or 44ft-lb, is this correct, it doesn't seem like that is enough?
Old Jun 3, 2011 | 03:50 PM
tbal's Avatar
Haters crazy
You didnt search, theres a few threads on this.
Tighten to 60nm
Shim spec should be between 0.35-0.45mm
Old Jun 3, 2011 | 03:53 PM
gaymg's Avatar
e55
I did search, 60 nm just doesn't seem like very much. You obviously didn't read my post clearly enough
https://mbworld.org/forums/w211-amg/...-help-pic.html
http://www.benzworld.org/forums/w211...lley-sl55.html
https://mbworld.org/forums/w211-amg/...ng-repair.html
https://mbworld.org/forums/w211-amg/...h-install.html
Old Jun 3, 2011 | 03:58 PM
tbal's Avatar
Haters crazy
It is what it is.
