BAMMM! Got a pothole...now have a question about my bent wheel.
Here are some pics:
So...what should I do? I can feel a very light shake so my options are:
1) Fix it and balance it. But I'm afraid it'll weaken the wheel further.
2) Just balance it. Would be the cheapest obviously, but will it balance?
3) Buy a new wheel. Obviously it's the best choice, but is it worth it ( About $300 or so )?
Aesthetically it's in perfect shape on the outside. It also holds air just fine.
Nothing honestly to screw with, don't leave it as it, at speed dangerous things could happen.
Ebay had a few replacment oem rims for cheap, and you can check the sale forum. I picked up a replacement oem rim for my winters when I bent one of mine.
If worried about it replace it.
I still am partial after seeing the vette flip in front of me due to a blown tire at the mile, so I tend to replace from now on.
Just went through this with a very slightly bent front wheel. Balanced perfect with no wiggles or vibrations and no pull to either side, but it wore the tire to the cords in one spot due to being slightly out of round. Could not feel a thing in the steering wheel and assumed everything was OK until an SA pointed out the problem.
Cost me $125 to have it brought back to true. Well worth the money.
I actually have my 19" wheels off my Audi right now since the fronts are both bent from pot holes or hitting something and caused a vibration. I checked in to getting them repaired by a place in my area and it is going to be roughly $150 a piece.
If it's out of round then I'll just buy a new wheel and keep this one as an extra.
Anyways, new wheel it is. I just don't trust fixing this one.
Even a wheel that doesn't look out of round can be slightly bent after hitting enough holes and bumps in the road, and this obviously includeds factory AMG rims as well. The only way to check for wheel roundness is to dismount the tire, put the wheel on a balancer that can measure lateral and radial runout (e.g., Hunter GSP9700), and determine whether or not the runout measurements are within specification. If either measurement is out of spec, you may be able to rebalance the tire on the rim, but you will still have vibration issues.
You won't regret your decision to replace the rim based on the pictures and your description.
