Paint Thickness Gage?
These devices are pretty pricey but I found one for $125. Have any of you or know anyone who has ever used this:
http://www.paintgages.com/category-s/12.htm
I'm willing to rent one but not sure if the local auto store has these?
I'd rather go with the more expensive units and just pick a single location and manually read/monitor each value.
There are other ways to check for paint work without a meter. Carefully inspect for trash in the paint, fisheyes or super smooth finishes that indicate buffing. Another tell tale sign is buffing compound (white powder spots) in hard to clean areas.
Take the tip of your finger and gently rub it along the edges of panels to feel if there are any rough edges which indicate tape lines or overspray.
Most cars that have had paint work are a result from an accident in the front end or back end so look closely there.
One of my dealer buddies does not like to use a meter in the auction lanes because you can miss obvious damage like a dent or scratches.
Emoving is all over this one. With a meter you are looking for consistent readings without a large spike.
Good luck!
Although expensive, the Elcometer 311FnF seems to be the industry benchmark.
Good luck!
http://www.paintgages.com/PaintGage-...Gage-FNF-A.htm
For me, it's harder to detect if a bumper has been refinished. I'm not too worried about bumpers because they can easily be repaired or replaced, I'm more concerned about metal work using bondo (especially on doors and quarter panels) due to any collision.
The cheaper PTG’s are used to test the thickness of paint on ferrous metals which can be an issue if the car has aluminum part. A more expensive version will test on both ferrous and non ferrous.
I work for a company in the UK which supply thickness gauges, I realize you probably would not want to buy from us because of the shipping cost. However we do a Sauter thickness gauge on our website that might interest you Sauter Digital Coating Thickness Gauge . I am sure if you search around you find the same product available in the USA.
