E55 Dyno - Before and after mods....
Anyway, I got side tracked with other projects (have to make the wife happy) and just now got around to having Jerry do some tuning on the dyno. I got some time scheduled at IPS and had Jerry do his magic. I was very impressed with his knowledge and customer service. He did a great job and was able to gain 105 hp and 52 ft/lb torque over the base tune.
Overall from stock I got some pretty good gains. Before and after dyno runs were done on the same Mustang Dyno and fortunately temperature was about the same:
Stock - 356 HP 421 ft/lb
Tuned - 461 HP 473 ft/lb
I want to thank Jerry at Eurocharged for the great job and the guys a IPS Motorsports for all their good work as well.
Here is the final dyno showing the first (base tune) and last runs.
Let me know what you guy think on the numbers
I also have the same mods as yours, I did took the 2nd cats off but without the pulley, just guessing I should have around 430WHP then, any idea?
although some dynos are def heartbreakers for sure
Some of the newer crowd to cars get so wrapped up with peak numbers they probably want to find a downhill 1/4 track. ITS THE GAINS when looking at before and after dynos.
As long as you know where you start and end on the same dyno, I think it'll give you an idea of how much you've improved. I think there are way too many different things that go into altering dyno numbers for anyone to compare.
I hit 400whp on a load dyno 100% bone stock and then like 465whp with my mods.I then went to a dynojet and broke 500whp
I would be interested in seeing what difference the mods made as well.
