07 E63 ESP light is on
Old Jul 21, 2011 | 09:36 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
I did a 0 - 145 pull the other night.
Car was fine few days later when I back the car out I notice the light came on.
I turn off the ign and restart and all was good.
It is back on again.
Any ideas on a reset.
Could it be brake dust or anything silly....
Thanks.. Sunil
Old Jul 21, 2011 | 09:46 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Could be a bad sensor.
Old Jul 21, 2011 | 03:48 PM
dannish23's Avatar
'07 e63 AMG, '06 e320 CDI, '07 ML350 4Matic, '18 Gls450, '12 cls550
i have the same problem, but idk what it could be
Old Jul 21, 2011 | 11:54 PM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
Prob your speed sensor. Can you you turn off ESP when you see this?
Old Jul 22, 2011 | 12:56 AM
sunil517's Avatar
No ESP button does nothing
The car also feel lazy and stiffer ride.
I was able to tune it off once I stop/start the motor.
Could is be brake sensor?
Old Jul 22, 2011 | 01:02 AM
aghakauve's Avatar
I think it's called the speed sensor. The car goes on another map something like a limp mode. That's prop why it feels sluggish. I have this same issue and I'm going to check it out once I get back in town.
Old Jul 22, 2011 | 07:39 PM
Shifter's Avatar
E55, SL63, ML550
On the 07+ (non-SBC)its probably a fautly steering angle sensor, built into the Steering column module(SCM)
Old Jul 27, 2011 | 07:57 PM
sunil517's Avatar
update..
I had new OEM pads installed. 145 to 0 stops a few times did produced some dust and its been about 3 weeks between cleaning. I decided to pull the wheels and wash everything,120 miles later no ESP light.
I am hoping it was just dust on a sensor.
Old Oct 3, 2011 | 08:33 PM
Pushing_Tin's Avatar
2007 E63
I floored it today to hit a gap in traffic and shortly after that I noticed the ESP was inoperative. I pulled over, turned the car off and restarted it and continued home without any issues, is this common?
Old Oct 4, 2011 | 12:56 AM
infantry's Avatar
07 E63. 07 STi limited #606/800
Happened to my 07 E350 with like 35k miles or so. Fixed by dealer easily, speed sensor or something. Sold so can't comment past that.
Hasn't happened to my 07 E63 yet.
Old Oct 4, 2011 | 12:59 AM
2007 E63
Did it stay on all of the time, or was it intermittent?
Old Oct 4, 2011 | 02:12 AM
infantry's Avatar
It would turn on after backing out of the parking spot when I would turn the wheel all the way, I think it effected it, and that warning came on, esp inoperative.
I was confused, turned the car off, and on. nothing. Drove it like that to my quick destination off base when I was in San Diego.
On the way back after the car was off for at least an hour, it didn't light up. But the next morning backing out of my parking spot, it went off again, and i took it to the dealer then so that it would still be on, left it running to show the tech.
It was quite fun to be honest without ESP.
Old Oct 4, 2011 | 12:49 PM
2007 E63
Came on again this morning on my way to work, anybody know roughly how much it costs to be repaired, and why does the suspension stiffen up?
Old Oct 4, 2011 | 08:07 PM
2007 E63
So I called a few dealers today and they both said between $250-$500, does that sound right?
Old Oct 4, 2011 | 11:06 PM
sack5000's Avatar
2015 AMG C63 S
agree probably a steering angle sensor, should not be a big job.
Old Oct 7, 2011 | 02:13 AM
2007 E63
Took it in today and that's what it is. **** happens but it is a little disappointing that a car with 39k miles on it needs this replaced already. BTW, I'll be in OKC in a few weeks!
Old Oct 7, 2011 | 09:51 AM
sunil517's Avatar
how much was the part? and do you have the PN?
I saw that error and like I said I clean the pads thinking that was it. So far I am good but if I can swap the sensor out and its cheap I will because it might come back again.
Did yours ride really stiff when the light was on?
Old Oct 7, 2011 | 02:16 PM
2007 E63
Yes, it's awful.
Old Oct 7, 2011 | 02:21 PM
timeToy's Avatar
'08 E63 Wagon
I needed to replace mine two weeks ago at 23.5k
Old Oct 7, 2011 | 04:05 PM
sunil517's Avatar
My car ride like it was bolted to the chassis.
If I get the code again I will change it out. Post the PN they install hope its an update part since this is a common problem.
Old Oct 7, 2011 | 05:51 PM
2007 E63
Car goes in Monday afternoon, they said it would take about 1.5 hours. Just picked up an aftermarket warranty which will cover it, total bill with diagnostic time was $480.
Old Oct 11, 2011 | 12:51 AM
2007 E63
For anybody else with this issue, the part number is: 211 5450116
MSRP is $252 which but it can be had for about $195 online. Not sure if it's a DIY or not, but my car is back to normal. The sensor was a lot bigger than I imagined it would be and it looked brand new. I don't think this part is updated.
Old Aug 15, 2014 | 04:11 AM
svtsnake99's Avatar
e63
ESP light
Same Issue With My 08. I Know Pads are Getting Down There. I Did A 140 Stretch And Came To A Quick Slow Down, Then The Light Showed Up. Pads?Or Sensor?
