Do These Adjustable Links Look Right?
I took them to a local shop to get installed and they said it wasn't the right links?? They took a look at the fronts and said it was too long. Can anyone confirm this? At it's shortest length the front links are about 4.5 inches long. They look like this:
[IMG]
[/IMG]
I actually just lowered the car more the other night,I can pop them off now with out even looking and just stick my hands in there with a flat head and pop them off.
all you need to do for the fronts is jack the car up a bit to fit your hand in there.
- Jack up rear of car (Jack stands)
- Crawl under with flashlight in your mouth
- Go to axle, and look up on drivers side just above the rear end housing
- You will see the link directly above the housing, just off center to the drivers side
- Pop off stock link
- Adjust new link (see below)
- Pop on new link
- Pop on new link
You'd have to attach one side and adjust the other since the whole end rotates to lengthen or shorten the link. Just take the stock one off and match them, then make a small adjustment. I had to jack the car up twice before I got the height I wanted. It's still not perfect, but I haven't had the time to get back under there.
Good luck!
The risk with that design is that if the jam nuts ever come loose you'll slowly lose your settings as the rod threads itself deeper into the heims. With some nyloc nuts (or a dab of Loc-Tite) the fine tuning adjustments would be quick and would not drift over time.
-G
By the way since we're at it can someone post instructions for the front as well? Do you just pop off the front link?
The rears I did 3 or 4 full rotations shorter than stock i think.
http://adjustableairride.com/
