Cancel Aftermarket warranty??
At this point (7months), is it better for me to get my $5k prorated refunded to me and have a nestegg for future repairs??
Below is what is covered and if not listed, not covered.
Engine
All internal, lubricated parts. Cylinder Block; Cylinder Head(s); Harmonic Balancer; Timing Chain, Timing Belt, Balance Shaft Belt, Gears, Pulleys, Guides and Tensioners; Oil Pump; Intake and Exhaust Manifold; Diesel Engine Vacuum Pump; Engine Mounts. The following parts are covered only if damaged by the FAILURE of an internal, lubricated part: Cylinder Barrels, Timing Chain Cover, Valve Covers, Oil Pan and Rotor Housing.
Transmission / Transfer Case
Manual Transmission / Transfer Case: All internal, lubricated parts. Flywheel; Transmission Mounts; Clutch Master and Slave Cylinder. The following parts are covered only if damaged by the FAILURE of an internal, lubricated part: Transmission Case, Oil Pan and Transfer Case.
Automatic Transmission / Transfer Case: All internal, lubricated parts. Flex Plate; Vacuum Modulator; Transmission Mounts. Torque Converter if internally damaged. The following parts are covered only if damaged by the FAILURE of an internal, lubricated part: Transmission Case, Oil Pan and Transfer Case.
Drive Axle (Front/Rear)
All internal, lubricated parts. Drive Shafts; Axle Bearings; Drive Axles, Stub Axles, Tripod Joints; Universal Joints; Constant Velocity Joints and Boots; Locking Hub Assembly. Drive Axle Housing if damaged due to the FAILURE of an internal, lubricated part.
Seals and Gaskets
Seals and Gaskets on all covered parts.
Taxes and Fluids
State and local taxes, where applicable, and fluids as required as part of a covered repair.
Air Conditioning
Condenser; Evaporator; Compressor; Accumulator; Receiver Dehydrator; Clutch, Pulley and Field Coil; Idler Pulley and Bearing; Expansion Valve; P.O.A. Valve; Orifice Tube.
Heating
HVAC Blower Motor; Heater Control Switch; Heating Cables; Heater Core. Fluids required as part of a covered repair.
Fuel System
Fuel Pump(s); Fuel Injectors; Fuel Injection Pump; Fuel Distributor; Fuel Tank; Metal Fuel Lines.
Cooling System
Water Pump; Radiator; Fan, Viscous Drive, Clutch and Motor; Condenser Fan; Cooling Fan Thermal Switch; Thermostat.
Braking System
ABS Control Unit, Wheel Sensors, Pump and Motor, Accumulator, Actuator Assembly; Master Cylinder; Vacuum/Hydraulic Assist Booster; Wheel Cylinders; Disc Brake Caliper, Pistons and Seals; Proportioning Valve; Metal Hydraulic Lines and Fittings.
Suspension (Front/Rear)
Upper and Lower Control Arms, Control Arm Shaft and Bushings; Upper and Lower Ball Joints; King Pins and Bushings; Torsion Bars; Strut Bar and Bushings; Stabilizer Bar; Links and Bushings; Wheel Bearings; Hub Bearings; Knuckle; Spindle and Support. MacPherson Strut Housing not including Shock Absorber or Insert.
Steering
All lubricated parts contained within the Steering Gear Box. Rack Assembly, Control Valve; Power Steering Pump; Power Cylinder Assembly; Pitman Arm; Idler Arm; Tie Rod Ends; Drag Link; Steering Column Shaft and Coupling.
Electrical System
Alternator; Voltage Regulator; Distributor; Ignition Module; Coil; Engine Wiring Harness; Manually-Operated Switches; Wiper Motor(s); Starter Drive and Solenoid; Starter Motor; Ring Gear; Anti-Detonation Sensors; Factory Installed AM/FM Radio, Cassette Player, C.D. Player and Speakers.
High-Tech / Convenience Group
Four-Wheel Steering Center Shaft and Couplings, Power Steering Unit, Control Unit, Control Valve, Speed Sensors and Oil Pump; Turbocharger, Intercooler, Wastegate, Wastegate Actuator/Controller; Supercharger, Pulley and Clutch; Computerized Timing and Mixture Control Unit and Sensors; Power Door Lock Switches and Actuators; Cruise Control Module, Servo, Engagement Switch; Power Window Motor and Regulators; Power Seat Motor; Power Antenna; Power Sun/Moon Roof Motor; Ignition Switches.
I brought my car in for service once and it basically paid for itself on the first trip...
I don't know what you did to your car so maybe for YOU it was worth it...but for me it's not.
What work did you get done and they covered? I took it in for leaky valve cover gaskets, leaking windshield tank reservoir, fuel sending unit. They only covered the valve cover. The fuel sending unit they considered a fuel filter and not covered. Neither were the gaskets for the windshield reservoir.
But they do cover road hazard for tires w/ no deductible.
Always a crap shoot on that engine and tranny.
One piston and it pays for itself. One tranny pop and it pays for itself
