Lowered on Links Now Car is Slammed?!?!
Hey guys,
I purchased some links on ebay and set it at its highest setting and look at the car??? I made the link as short as possible and this was the result![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I definitely can't drive like this...can anyone help or know why its THIS low??
(I've only done the fronts so far)
![](http://img.photobucket.com/albums/v736/stilzx61/IMAG0315.jpg)
![](http://img.photobucket.com/albums/v736/stilzx61/IMAG0317.jpg)
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Correct you don't have to remove any sensor. All I am saying it is easy to make a mistake and flip the pivot arm the other way when installing. Like someone said 2 to 4 mm longer than stock should give you the desired drop.
Guys it does look good but why on earth is it so low? I'm going to check to see if I installed it incorrectly like shardul mentioned. But has this happened to anyone?
Two 957 Cayenne GTS's (black and silver), Duc749 (dark), departed '03 E55
Yeah, you may be hitting the rise button a lot to get over things, but it does look pretty good.
