CEL after swapping Air Boxes 07 e63
Former Vendor of MBWorld
Whatever we're tuning!
Dannish-
MB Generic
DTC DTC
1350 P0101 The measured right air mass is implausible compared to the position of the throttle valves. (P0101)
1351 P0101 The measured right air mass is implausible compared to the position of the throttle valves. (P0101)
1352 P0101 The measured right air mass is implausible compared to the position of the throttle valves. (P0101)
0502 P0327 A16/1 (knock sensor 1, right) (P0327)
The ECU needs to be reset. Dosconnect your battery for ~20minutes and it will clear the P0101 codes and then you can STOMP THAT $H!T!@!
Be diligent and make sure you installed them correctly. I've seen the bottom of the y-pipe dislodged causing this issue also.
MB Generic
DTC DTC
1 Post
2007 E63, 2005 Dodge Ram Hemi
I had a tune, put in BMC's, and pulled my charcoals and would throw the lean code every couple hundred miles...Turns out my valve cover gaskets were leaking...Fixed under warranty and never a code again
'07 e63 AMG, '06 e320 CDI, '07 ML350 4Matic, '18 Gls450, '12 cls550
