CEL after swapping Air Boxes 07 e63
'07 e63 AMG, '06 e320 CDI, '07 ML350 4Matic, '18 Gls450, '12 cls550
There are many threads on this issue that i have searched, but none seem to give me a straight answer.
I swapped my stock air boxes with Air Boxes modded by bruce at ttm, I also took out the charcoal filter before putting the modded boxes on.
Now all i have on is the modded air box, and green filters.
Everything was fine until i slammed the gas pedal earlier today and floored the car, as soon as i did that, a CEL light came on, what to do now?
I'm taking my car to the dealership Tuesday to get it serviced so idk if I should wait till then and let them reset it.. What do you suggest
I was planning on doing a tune, but only after some pulleys being installed. Just paid fo school so a bit low on cash for now as far as a tune goes..
If it was me, I would get a scanner from autozone and see what the code is. The scanner will also allow you to reset or clear the code.
Autozone will read codes for you for free. Start there and then look up the code, and im sure someone here will be able to help.
im taking it to the dealer tomorrow or tuesday for "ESP Malfunction" ill tell them to clear the codes, but will they pick up on the air boxes?
also, a little off topic, but does anyone know what gains (if any) should i be expecting after installing the modified boxes on my car?
Registered User
too much air flow requires more fuel + less restrictive exhaust .
Here is where the fun starts ! Tune to increase fuel and also remove a set of cats for more flow and u will be OK .
Clear the codes for now and dont to any WOT runs until u get the car back from dealer .
prior to modding my car when i removed the intake baffles and also the charcoals and added a K% N i only got the CEL went i did blasts past 120 MPH . Under normal driving it would shut off .
Everything was fine until i slammed the gas pedal earlier today and floored the car, as soon as i did that, a CEL light came on, what to do now?![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
M3 & E63 & SL55
This happened to my car as well. I changed the filters to K&N and took out the charcoal filter about 50 miles later the cel light came on. Cleared the code it read p0175 which is a maf malfunction. The light came on again put it back to stock and the code cleared itself. Not sure what the problem is.
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Get a tune and you'll be fine.. The car isnt use to all that air! But defiantly fix your ESP malfunction first before you get a tune.
no money for a tune right now, ill try to get the dealers to clear the code, now im debating whether to put my charcoal filters back in or not
Its okay. I would go back to stock and then when you get some $$$ to get a tune throw the box back on. Remember when I told you when you start tuning these AMGs you really have to pay to play lol. I think the best bet is to go back to stock just to be on the safe side.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you knock sensor is still bad? i though you told me you got it fixed. last time when i ran star diag that code was present. good luck on getting that fixed!
