E55 722.643 Transmission Rebuild PICS
My first foray into transmissions was 20+ years ago with my 944 which lost it's ring and pinion from a 5k clutch drop. I had to rebuild that gearbox 4 times as I was not getting the backlash and bearing preload correct and blew through 2 more. $650 a pop! LOL. I can laugh now about it now.
This is the odd valve that is held in with its own pin.
Thanks!
i was swapping the 500 engine out for the 55 amg and while i was mating the tranny to the new engine i did my best to align both visible gears on the tranny spline with the torque converter but the engine and tranny didn't align as smoothly as one would expect. i had to "Catch" the bell housing on the engine through the tranny with the bell housing bolts to crank the tranny to the engine. heard two "clunk/clank" noises while forcing the tranny and discovered one of the two places where the bell housing tabs stick out into the tranny (to align it properly) was slightly damaged but still usable.
is there anyway to see if i damaged my tranny without disassembling it? all teeth on spline look good and female spline inside torque converter looks fine
my question is, do you think i may have damage the tranny oil pump or just the torque converter? i didn't see any visual markings on any of the splines or surrounding assemblies but i did notice some metal flakes on the spline when i took them apart again
https://www.dropbox.com/s/esay4d7iht...2021.26.40.mp4
I pulled the tranny out today and have some other questions.
On the input shaft, the smaller shaft that's inside the other one, mine has a LOT of side to side play and i cant remember about end play.
I took off the bell housing and the first pack that is attached to bell housing is solid as can be.
The K2 one, the outer "cage" looking part is all loose compared to the shaft and the parts inside it. Shouldn't that whole assembly be pretty solid? That's what i could wiggle around through the hole too.
Ill take another video and post it
Also the output flange and shaft are very solid as is what is left in the tranny when you pull out the K2 pack.
THANK YOU! for any advice or help
the reason why I am checking out this thread is because I have an issue with my transmission. whenever I am driving it locks on 2nd gear and will not pass, 2nd gear is locked on comfort mode.so whenever I go over 40 miles per hour the RPM is at like 3500 and when the car starts to whistle from the bottom where the transmission housing.
now it starts to whistle when I go over 25 miles per hour. brought it to my mechanic he said he needs to open up the transmission but the cost is really high. .anyone here know anything about what this problem can relate to is a gear problem is a pump I don't know what the problem is. I am pretty sure that you guys can come up with an answer unless you see the car I understand but what can be the possibility any options
BTW the thread here is incredible
The reason it's stuck in 2nd gear has nothing to do with "comfort mode"
It's stuck in 2nd gear because your transmission/tcu has an electrical problem
When there's a mechanical problem your transmission stays in 3rd gear.
Your transmission computer is most likely just fried from your transmission leaking fluid into it. Sometimes they are salvageable
I would order a pan gasket, a trans filter, a conductor plate, the infamous connector, and fluid
I had an identical failure mode last year and it was the conductor plate, many others have had plate failures and experienced similar results especially on cars with 80k+ miles.
Even if it isn't the conductor plate, you will need a new one when you rebuild so you are only purchasing the item ahead of time... if that doesn't solve your issues.
Spend $150 on a Mercedes dealership diagnosis or spend $150 on a conductor plate. I chose conductor plate.
the oil pump and the clutch really have to say they did an amazing job a little pricey but incredible. Now my baby has 125K miles
Sounds like they didn't do such an amazing job. If the transmission has already been apart, there's not much the average owner can do for you on this site just by defining the issue. Time to take it in and spend money again.
