Engine Vibration at Specific RPM
Old Jul 31, 2011 | 10:57 PM
izzyz28's Avatar
2004 E55 AMG
Hi All,
My car has had an engine vibration since I got it 50,000 miles ago. It's not drivetrain-related as it occurs even in park. I feel it most(in the seat) when the engine speed is approximately 1,500-2,000 RPM under low load conditions or in neutral. It's not the balancer as that was replaced with the 180mm pulley/balancer and the vibration stayed exactly the same. I replaced the motor and tranny mounts a while ago, and though it lessened a bit, it was still there.
My only thoughts are that it's a harmonic(which should mostly be taken care of by the balancer), or the exhaust is somehow transmitting it to the floor of the car. I've been under the car numerous times and all the rubber exhaust insulators are good and nothing is rubbing. I should also mention that I get a rattling sound around 20-25mph in cold weather when I accelerate lightly in third gear, then it goes away as soon as the car gets some heat in it. I'm pretty sure it's not the CATS, as I've even beaten on them with a heavy rubber mallet and no rattle. I've always just accepted it, but I wanted to see if anyone has experienced this. Thanks!
Old Aug 1, 2011 | 09:43 AM
grantwoodtx's Avatar
GLE 63S
Search for "engine mounts"
Old Aug 1, 2011 | 09:51 AM
izzyz28's Avatar
2004 E55 AMG
As I said in the OP, "I replaced the motor and tranny mounts a while ago, and though it lessened a bit, it was still there". Mounts have been replaced.
Old Apr 22, 2012 | 01:03 PM
pasamoj's Avatar
E500
Hi There,
Did you ever find out what the source of that vibration was? I think I have the same problem on mt 03 E500
Originally Posted by izzyz28
Hi All,
Old Apr 22, 2012 | 01:26 PM
ahmad0658's Avatar
Brabus K8 E55 05
I have similar issues, exact description, you can feel the vibration inside. I have no codes.
Old Apr 22, 2012 | 02:40 PM
kelwilliams08's Avatar
CL 55 AMG
having the same issue here, im curious if its a tranny issue ( i.e. torque converter) i think im going to have mine replaced this week and see what happens
Old Apr 22, 2012 | 02:48 PM
edmond1129's Avatar
E55
Same here with the problem. Got header, 2nd cat delete and tune
Old Apr 22, 2012 | 02:50 PM
izzyz28's Avatar
2004 E55 AMG
I did! I replaced the tranny mount and the vibration was one hundred percent gone.I was honestly stunned that it worked. I believe that the first time I did the tranny and engine mounts I fastened everything down without making sure the tranny was dropped straight down onto the cross member, which caused the mounts to be slightly twisted and bind. I would recommend replacing the tranny mount only and ensure that all the bolts are in and nothing is cocked before tightening them down. FYI, I used a cheap eBay mount and it works great!
Old Apr 22, 2012 | 03:16 PM
blackbenzz's Avatar
haters crazy
It could be the driveshaft coupler or center bearing since you already replaced engine and Trans mounts
Old Apr 22, 2012 | 03:52 PM
izzyz28's Avatar
2004 E55 AMG
It certainly could be. I would slowly bring up the engine speed in neutral or park to see if its power train or drive train related to help isolate the source.
Old Apr 23, 2012 | 10:36 PM
pasamoj's Avatar
E500
Thanks for your reply. I did replace engine and transmission mounts and I think there was little less vibration first couple days after replacement but its back to where it was before replacement. I don’t think anything is twisted or out of place on transmission mount. I suspect harmonic balancer on mine, we’ll see. Thank you very much.
Old Apr 23, 2012 | 11:46 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
have you done the rear flex disc?
Old Apr 23, 2012 | 11:53 PM
pasamoj's Avatar
E500
I don’t think it's flrx disc since I feel vibration even when car is in park. More noticeable when engine is cold.
Old Apr 24, 2012 | 12:02 AM
blackbenzz's Avatar
haters crazy
Is your seat massager on?
Old Apr 24, 2012 | 12:04 AM
pasamoj's Avatar
E500
LOL
Old Feb 22, 2018 | 08:23 PM
Turan's Avatar
MB w220 S500
Vibiration
Hi.ihave S500w220. With 722.6 tranny. i have same problem with the vibration. So when the car is cold and i get the engine on. Ithas terrible harmonic vibration around 1200-1800rpm. But when the engine temprature goesupto 70 C there is no any vibration. All mounts is in good conditions.
Old Feb 22, 2018 | 08:59 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Make a new thread in the correct section. This section is for the W211 AMG cars.
Here: https://mbworld.org/forums/s-class-w220-16/
