Tires Rubbing HARD!
Old 08-02-2011, 09:56 AM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
Tires Rubbing HARD!
Hey Guys,
Put on new SL wheels on my car but the rears are rubbing so hard like my gf giving me a hand job or something (trying to make a point). But anyways, the rear fenders I know aren't rolled on E500s so wondering if I have my fenders rolled like the E55s do, will I have a problem?
Fronts: 255/35/19 ET30
Rears: 285/30/19 ET31
Old 08-02-2011, 10:02 AM
skratch77's Avatar
2005 E55
ET 31 what did you expect,those will prolly rub on an e55
Old 08-02-2011, 10:03 AM
djrabbi's Avatar
well my winter CLS wheels are like 23 in teh rear......only rubs when road is wavy.....
Old 08-02-2011, 10:11 AM
djrabbi's Avatar
winter wheels are
245/40/18 ET25
275/35/18 ET28
Old 08-02-2011, 10:14 AM
skratch77's Avatar
2005 E55
275/18 vs 285/19
Old 08-02-2011, 10:15 AM
djrabbi's Avatar
lol I know this too...That is what I am asking... since E55 fenders are rolled, would this wheel fit since I am getting mine rolled today...I don't think offset is the issue here
Old 08-02-2011, 10:19 AM
skratch77's Avatar
2005 E55
Im running a 35ET on 275/35/18 that run wide like a 285 and they will rub in s2 on hard turns.So no way would I be able to run an et31 with my tires
the lower the et number the more it pushes the wheel out towards the fender.
Old 08-02-2011, 10:20 AM
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
how wide are the wheels? if they're 10.5 in the rear your gonna need to pull the fender a bit if you're lowered.
djrabbi's Avatar
9.5 rear....
Old 08-02-2011, 10:21 AM
djrabbi's Avatar
I am looking around, a lot of people have the SL65 2peice wheels which are same offets on E55's.....
Old 08-02-2011, 10:25 AM
skratch77's Avatar
2005 E55
pretty sure they are running a 35mm offset,you might be able to find a thinner tire.
But Im almost 100% sure people that run 19s use a 35mm offset in the rear
Old 08-02-2011, 10:27 AM
skratch77's Avatar
2005 E55
http://cgi.ebay.com/ebaymotors/19-EU...Q5fAccessories
Old 08-02-2011, 10:30 AM
djrabbi's Avatar
http://m.www.mbworld.org/forums/showthread.php?t=133698
Old 08-02-2011, 10:33 AM
skratch77's Avatar
2005 E55
read the thread as one person thinks there fake and Im with him,he has cloned sl65 wheels made in a 35mm offset
Old 08-02-2011, 10:34 AM
djrabbi's Avatar
yeah just saw that....how is this possible?
Old 08-02-2011, 10:38 AM
skratch77's Avatar
2005 E55
Iv been going back and forth trying to get custom 18s made for my car with forgstar since IM trying to run a skinny running 315/30/18 drag radial so I know what offsets we have and can play with.I need like a 38.5mm offset on a 10.5 in wheel and I would still need to roll my finders to get it to work,I kinda gave up on it lol.
you are at the limit with that offset and you might find a thinner tire that might clear the fenders.
Old 08-02-2011, 10:40 AM
skratch77's Avatar
2005 E55
simple just call tire rack and ask them if a 19in wheel with 31 offset will fit your car with a 275/30/19
djrabbi's Avatar
I have PS2 on the tires and heard those are the skinniest tire...I had 285s before but they were 35mm...didn't think 4mm made a big difference! I raised my car for the time being but rubs only at sharp turns...so thinking of using star to do an auto calibration and see from there
Old 08-02-2011, 10:44 AM
AMG_RL's Avatar
your fender's aren't rolled right now correct? get them rolled and you should be fine. a 9.5 with a et31 offset is still pretty conservative, you shouldn't have any issues once the fenders are rolled. most likely due to the 285 tires in back.
Old 08-02-2011, 10:45 AM
djrabbi's Avatar
yeah E500 don't have fender's rolled like E55s......So yeah I am thinking I will still rub a bit if I lower it too much...I might just go back to stock height and lower it "two-three clicks" all around.
After I drove around the block....you can smell the rubbing badly. I tried to put my hand to see how bad, it was too hot too touch, but didn't see all that bad...
Old 08-02-2011, 10:49 AM
skratch77's Avatar
2005 E55
try a 275/30/19 tire if the rolling dosnt work
Old 08-02-2011, 10:50 AM
djrabbi's Avatar
yeah that will be my LAST resort since i paid like $1000 for the rears but I do have 275/30/19 nittos so we will see
Old 08-02-2011, 10:53 AM
AMG_RL's Avatar
you should still have plenty of room to lower the car w/o any issues after you roll the fenders just make sure someone knowledge does the rolling, don't want to end up with cracked paint.
djrabbi's Avatar
yeah found a guy who has been doing it for 10 years lol....
p.s. what is a good lowering point....mine is all ****ed with with fronts being too low compared to rears.....i want the car sitting on top of the tires look.
Old 08-02-2011, 10:57 AM
AMG_RL's Avatar
leave about a finger gap all round and that should give you the look you're going for. with a raked setup(front lower than rear) you run the risk of rubbing severely on the inside of the front tires. My car is tucking tire all around with the front slightly higher than the rear.
Quick Reply: Tires Rubbing HARD!
