Plastidipped grille,tint,lowered 63
Old Aug 3, 2011 | 05:18 PM
Juggernaut23's Avatar
94/95 Supra,07 E63 AMG
Lightbulb Plastidipped grille,tint,lowered 63
I decided to lower the 63 with the washer method and that took only 20 minutes to do so I tinted it with 45%.I had a little more time left so I decide to paint the grille with Plastidip to try it out and see if I like it or not.If I dont like it I can peel it off since it dries like latex rubber and removes in minutes.Anybody no where to get a black grille for the 07 63?
Old Aug 3, 2011 | 05:20 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
looks nice
TheVazha's Avatar
W213 E63
Looks great!!
Old Aug 3, 2011 | 05:37 PM
E55Dimon's Avatar
E63S
Old Aug 4, 2011 | 01:26 AM
nicco's Avatar
E55 AMG
I like the flat black on the grill, makes it stand out a lot more.
Old Aug 4, 2011 | 05:49 AM
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
How did you prep the grille?
Old Aug 4, 2011 | 08:16 AM
I wiped it clean with a old T-shirt and Q-tips and used rubbing alcohol to clean it.Then sprayed it a few times til all the chrome was gone.This stuff is great for testing.Lots use it as permemant but not me. Look at these videos and be amazed how well it goes on and how simple it comes off. No glue or residue.It will stay on long as you like if you choose to keep the look.
http://www.youtube.com/watch?v=BP_IKoxSgF4
http://www.youtube.com/watch?v=HLsu6...eature=related
http://www.youtube.com/watch?v=GXpIuEBBHWo
http://www.youtube.com/watch?v=f_ZZxWjoIsk
A tip for those who do this. If you were to paint on racing strips or large areas on the body please use a razor and let it glide along the tape line before peeling off the tape or it will lift on you. You dont have to apply pressure with the razor just enough to score it for it to peel off with out lifting.
http://www.youtube.com/watch?v=yE7NQB06wG4&NR=1
Old Aug 4, 2011 | 02:27 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
anyone else have experience with this plastic dip??? I would like to use it on my grill
Old Aug 4, 2011 | 05:56 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I think few people did it but not sure how long will last specially in the front grill will chip out easier. Or instead of spraying 4 coats, go for 7 coats might last longer.....
Old Aug 4, 2011 | 08:18 PM
anytime you get a nick or scratch just hit it with a quick spritz of the spray. It blends perfect.Easy touch up. I rather buy a black grille done already,but that is just me.
Old Aug 5, 2011 | 12:21 AM
FromM3toE55's Avatar
2003 E55 AMG
looks very nice!
Old Aug 5, 2011 | 12:38 PM
CharlyE500's Avatar
Did you have to remove the grill to spray or just cover with paper ?
Old Aug 5, 2011 | 01:14 PM
BenzoBoi's Avatar
Super Moderator
W221
Looks fantastic!
Old Aug 5, 2011 | 03:25 PM
The grille came off in 2 minutes flat with just 5 8mm bolts.I took it off and sprayed it since it was so easy to do so.
Old Aug 5, 2011 | 03:54 PM
iceman-kimster's Avatar
2009 E63
Im going to do this!.. did you just use 1 can for the grill? and where can you buy this plastidip?
Old Aug 5, 2011 | 05:51 PM
Home depot sells it.Its main use many years ago was to dip your pliers and tool alike into it to make new rubber handles.Now they make it into a spray can in many colors. I used alot on my grille,about 1/2 of a can. And if you dont like it just peel it off,leaves no residue.
