- Mercedes-Benz E-Class and E-Class AMG: Why is My Serpentine Belt Squeaking?
Step by step instructions for do-it-yourself repairs
update on belt noise/chirps fixed!!!
I will be keeping the asp pullies for now
I had a problem with belt noise and squeaks on normal driving and would be the worst on cold start up.
This was on a cold start.
I did get a battery in red on the dash today to visit workshop so i dont know if its a coincidence that my accessorie battery is going bad.
after changing the surp belt it still did it and I said what the heck ill try a new s/c belt and my car has been noise free for the last 4 months from swapping the s/c to a longer one
It's getting progressively worse...goes away when fully warmed up, but gets louder and louder each morning. It also gets louder the higher the revs are. Could it still be S/C belt you think?
Sounds like your tandem pump bearing is starting to go. Do you have between 50 and 70K on your car? The majority of ABC failures occur between 50 and 70k so that sounds to be the culprit. Hook up an SDS and check the ABC pressure and it should be ~190 bar. Even if the pressure is fine that grinding noise could be flooding your ABC system with metal fragments if it is your pump beginning to fail.
Have you gotten any Visit Workshop messages related to your ABC suspension? The earlier you catch a failing pump the better since the meatl in the fluid WILL DAMAGE your valve blocks and then the repair will be ~ triple the price of just a tandem pump replacement. Good luck and if you want to give me a call in my office I will be happy to explain in depth what needs to be done. I have done over 2 dozen ABC tandem pumps so I do know this system inside and out!
Why would the bearing noise go away once the car is fully warmed up however?
I did just have an ABC fluid and filter flush from the dealer a few weeks ago.
