widest rim for the front? 10"?
in order to get the concave on the rim i want I would need to go 9.5 or ideally 10 at the front.
with a rolled fender and stretched tire can either size work?
10.5 for the back.
10.5 for the back.
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
a 9.5 wheel with a et20-25 should work, I know a couple people that have ran et18 on a 9.5 wheel, but you will definately have to pull the fender's and rock a 245 tire so there will be a slight stretch.
are you going for pure aesthetics or functionality as well?
2007 E63 w/P30 and Eurotech CF Diffuser
Wow, I did a search and this thread is recent.
I noted above that although the rim can go wider, the tire cannot?
I would like to put a 265/35-18 in the front on a 9" stock rear.
Anyone have any experience with this?
as for a 265 tire in front that is doable on a 8.5" wheel, however, correct offset as well as lowering and rubbing issues will all come into play. and let's not forget the heavy steering feel. I highly doubt it would work on a 9" wheel unless you run a LOW offset and pull the S*** out of your fenders. I personally have run 255's and 245's up front and the 245's just drive so much nicer.
