IAT's dilemma on the EV12
A friend last night (Mike, thanks buddy) along with my brother installed a Mezziere pump and replaced the tiny CM30.
With the CM30 IAT's were:
Cruising 135-140
WOT 149-155
With the Mezziere
Cruising 160-180
WOT- 155-175
Something tells me the mezziere is flowing so fast it doesn’t give the water enough time to cool down in the heat exchangers.
We are adding a rear 5 gallon reservoir right now, let’s see if this helps. Goes to show you more flow is not always better.
At this point it seems we need to increase cooling capacity and more water to dissipate the heat faster. If all fails, then it might be time for Meth.
What about burping....clueless on 12s brother. THey need to be burped for air like our Komps???
If you go down in pump size and IAT's come back down, I am ditching my 90s once and for all. Maybe THIS has been my achilles heel all along. I die a thousand deaths by the end of the 1/4
Keep my updated buddy!
With the rear reservoir you will not need to bleed the system as it is self bleeding, the water comes in an out and gets rid of air. We shall see tonight if this is the issue. If its worst I am dumping the Mezziere immediately and going back to my CM30.
The pump is just too monstrous of a pump...
I wonder if there is a thermodynamics engineer lurking around on the forums that could shed some light on various reasons why there is such a divide between seemingly similar systems. Perhaps there are variables we aren't taking into account?
Simply because you are experiencing an increase in IAT's by switching to the Meziere, in my mind, doesn't provide definitive proof that using one pump over another is better for everyone.
Pump efficiency is directly related to how much resistance (in pump lingo sometimes referred to as "head") it's pushing against.....in a cooling system with a lot of extra hose and restrictive 90* fittings you will create more load against the pump and the flow rate will be lower.... In a more efficient system, that pump won't see much resistance and will flow close to it's peak output.
I might be stating the obvious to you guys.... But if I wanted to test a "flow is too fast" theory, I'd find a way to put some restriction in the cooling hoses and measure those IATs again. A few quick tests and flow changes should prove (or disprove) that theory without the effort of tearing out the pump and replacing it with something else.
-G
Kinda thought so after watching Mikey use those little Johnson 30's and torch the track and all his ice in the 5 gal res. Seems perfect flow for his setup.
As for the pumps, my original setup consist of 2 CM30 in line with each other and flowed extremely well. After reading some good reviews on the Meziere I decided to install a single pump in place of the 2 CM30's, not even close in comparison. The single Meziere flowed like a gently river into my rear reservoir, while the 2 CM30's gushed like the rip roaring rapids. Chiromikey has the identical 2 CM30 setup and when we compared both cars side by side, it was very clear which setup performed better.
As you know, I datalog the crap out of my car and IAT's were always much higher with a single Mezeire pump, plain and simple. I'm sure others are having great success with the M pump (without the rear reservoir) but I would never personally recommend one after seeing the results. Just my $.02.
Yesterday I blasted it to 120 and Luis is witness it dropped to nearly 100, I could have sworn I saw 97 degrees at one point. Seems that the faster air hits my big front mount the faster it cools it!!! Temps last night were 82 degrees.
Seems I just needed to expand water capacity and add 2 bottles of water wetter. Problem solved.
I am still considering Meth.
This setup was used by exotic metal in the texas mile, and after a burn out, 35 sec 180mph run, and a mile drive back to the pits area the water flowing was still cool, ice had melted.
The flow pattern is as follows
s/c > front h/e > rear tank > rule2000 in tank pump (which pushes the fluid to the meziere up front and back into the s/c cooling core
IMO Next step should be Meth
If you run a front pump, then you need an intank pump to push water to it. Thats why I run a huge Rule 2000 intank pump to feed my front Mez. I flowed tested every combo excpet the CM90 pumps. Rule 2000 pushing to the mez rules! With Ice in the tnak, I can actually run to cold. lol
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
