Can battery control module failure cause batteries to drain??
Old Feb 11, 2014 | 12:46 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Originally Posted by E55AMG05
No not at all why r u saying that what the hell I just want the part number PLZ
weren't you the one who's car broke down in traffic, so you got out and broke the front bumper?
Old Feb 11, 2014 | 07:39 AM
E55AMG05's Avatar
2005 E55 AMG
Originally Posted by G_Money
weren't you the one whose car broke down in traffic, and you got our and broke the front bumper?
Yessir that's me. My car will be done on Friday from the body shop been der for almost 3 weeks. Ugh always something with these cars
Old Feb 11, 2014 | 08:57 AM
Joncl's Avatar
E55
I posted the part number for the aux relay
Old Feb 11, 2014 | 10:18 AM
novae500's Avatar
W211
You see that's BS there is no relay for the F***KIN AUX there is only a BCM that controls all OK!!! Srry I have been going through this prob since OCT. I am losing my mind. I can't stand it every1 asks about my AMG and I have to come up with something to lie and make a excuse. If there is a aux relay PLZ PLZ GIVE ME D PART NUMBER
There is a front relay under the PS windshield that connects to the front aux battery. Ask me how i know and what fixed my Codes i had.
Old Feb 11, 2014 | 10:22 AM
novae500's Avatar
W211
1. replace aux battery
2. replace trunk battery
3. replace volt reg.
4. replaced front relay
5. replaced BCM in trunk
I went through this. Took over 3 weekends to figure out and troubleshoot. After each step, i tested the voltage w/car off and car on. Would still get the codes.
In the end, after step 5, i didnt get "Convenience functions are disabled or the RED Battery icon". Luckily i have been fortunate since then.
Old Feb 11, 2014 | 10:44 AM
E55AMG05's Avatar
2005 E55 AMG
OK I GET IT I AM DOING IT NOW BUT PLZ PLZ WHAT IS THE PART NUMBER FOR THE FRONT RELAY OF OUR CARS?
Old Feb 11, 2014 | 10:55 AM
  #32
Joncl's Avatar
E55
Dude I posted it last night , here it is again
A0025423819
We are all here to help each other so just relax and stop kicking your car in the middle of traffic lol
Old Feb 11, 2014 | 11:19 AM
  #33
novae500's Avatar
W211
Take a valium mang. We are here to help resolve common issues that we run into. I remember you changed the vr on a used alternator and still get rid of the codes. Pretty much process of elimination is how i went about it. I hated that it happened during the hot 100 degree summer and working on the car. But end of the day, it put a smile on my face that i saved lots of $$$ DIY it myself and fixing the cause.
Old Feb 11, 2014 | 04:12 PM
  #34
E55AMG05's Avatar
2005 E55 AMG
A0025423819
I understand but saying that my car is a flood car is an insult. I'm PISSED I JUST F***IN SPENT $900 on a brand new battery rear and front and alternator from the dealership. I ordered online a brand new BCM for $324 on a mercedes parts website. I JUST COPIED AND PASTED THE PART NUMBER A0025423819 AND LOOKED IT UP. THAT PART A0025423819 DOES NOT EXIST. IT'S NOT ABOUT MONEY IT'S ABOUT THE PROBLEM IM TIRED OF THIS BS SINCE OCT. & FLOOD CAR MY *** AND I NEED THIS CHIT FIXED. DEALER DOESN'T KNOW ISSUE ALL IS POINTLESS AND DEALER SAID THAT THERE IS NO RELAY FOR AUX BATTERY'S AND HATERS(cousins & uncles) keep making fun of me about the car. I dnt want to sell and be made a fool of I need it fixed PLZ MORE OPTIONS PLz
Old Feb 11, 2014 | 04:22 PM
  #35
Joncl's Avatar
E55
http://m.ebay.com/itm/2004-Mercedes-...-/390422898847
All I did was google that part number
You got to relax bud
Old Feb 11, 2014 | 04:24 PM
  #36
Joncl's Avatar
E55
You can shop around and get them for 70$ sometimes
Old Feb 11, 2014 | 11:26 PM
  #37
E55AMG05's Avatar
2005 E55 AMG
Thx man I appreciate everything from everyone here honestly I googled the part not bad but will not purchase unless its A OEM. These dumb F**KIN 55K owners buy aftermarket electrical stuff when not bowing that everything has to be coded and programmed to the computer dumb
Old Apr 6, 2014 | 10:00 PM
  #38
realien's Avatar
2016 AMG GTS
I'm actually going through this, just replaced both batteries,
Traced drain to about 180 milli amps, but if I completely disconnect the rear SAM module ( the extra terminal on the positive battery terminal clamp), drain drops to zero.
I haven't replaced the voltage regulator ( seeing 14+ volts at idle) and haven't replaced the BCM yet. the aux battery relay someone posted, where is that physically on the car, right next to the aux battery (which I just replaced) and the E500 part is interchangeable with the AMG W211 ?
Old Apr 16, 2014 | 05:14 PM
  #39
realien's Avatar
2016 AMG GTS
Just as a follow up my battery drain appeared to be a after market relay that was locked open so it was providing power to a rear view camera all the time.
Old Jan 2, 2016 | 07:29 PM
  #40
new211e55owner's Avatar
mercedes benz w211 e55
daym
Old Sep 4, 2019 | 12:38 AM
  #41
Gabe1's Avatar
mercedes
I had same problem with 2.2 amps and fixed it. w211 2005 E320
pulled fuses one by one, it was the 40 amps sound system Audio gateway in trunk SAM, fuse # 6, I replaced the unit $70 I ended up with only 0.18 amp.
the unit is behind the trunk SAM left. SOLVED for good.
Old Feb 19, 2021 | 03:08 PM
  #42
rick Y's Avatar
03 W211 E500
🤦‍♂️ Fixed mine
I had this same issue. Went through all of this. Finally I changed the negative battery terminal, cleaned the wire with a wire brush and boom 🤯 problem solved. All that headache and money for a $4 fix. Was ready to stick a rag in the gas tank and let it go
Old Jun 11, 2021 | 04:34 PM
  #43
azdrewgz's Avatar
2003 SL500
Ok so I was torturing myself with my consumer battery at 11.76V every morning...took 10 min. of driving to go away and get consumers back..always had the "Consumer Electronics Offline" message when I turned the car on. Tested 14+V while running....Well...Someone pointed me in the right direction..My center armrest console latch is broken..like many other owners...and of course when I open up the large center console, the little light comes on. Well I stuck my iphone in there with video on record to see what happens when I close the lid with the car off..what do you know? The light remains on!!!! I disconnected the light and will test it tomorrow. This had to be a drain, let's just hope it was THE drain causing the battery discharge.
Old Jun 11, 2021 | 05:45 PM
  #44
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
See here ...
https://mbworld.org/forums/w211-amg/...003-fixed.html
Old Jul 29, 2021 | 02:37 PM
  #45
corgs77's Avatar
2006 E 500
Battery Control Module
Well gentlemen the BCM is no longer available. I just bypassed the module by connecting the negative battery cable to the rear wall of the trunk. Tada, car starts and runs! Hang tough.
