Who is going for 1/4 mile PB this fall?
Old Sep 13, 2011 | 10:04 AM
chawkins2001's Avatar
2006 E55 AMG
Oh, and I am shooting for 10's myself, hopefully I wont have to add the sauce to get there Once that is accomplished, she will be terrorizing the streets only!
Old Sep 13, 2011 | 10:09 AM
2006 E55 AMG
Originally Posted by Exotic-metal55
At least the E class can do sick burn outs, the damn CL has extra TQ mgt and it bogs down in the water box. Damn struggle each time to get tires hot.
Why is everyone selling thier track tires?
Mine does the exact same thing, bogs down with TQ mgmt
Old Sep 13, 2011 | 10:12 AM
2006 E55 AMG
Originally Posted by urbamworm
Weird, my 05 will spin power braking no problem. Just hit the traction control button and let her eat. I would sit in place for only like 2 seconds before then rolling forward spinning since I was only on street tires though so no reason for anything crazy but it lets me spin. What do you mean by it won't let you do a burnout, like it instantly kills power or you can't sit there for 10 seconds if you wanted?
click
Can you reveal your settings with the tranny, ie C, M, or S? How hard do you brake, and do you floor the gas once the brake is on or just gradually start the burning
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
I think you guys should maybe try holding the brake, start spinning for a second or two, let off the brake and then quickly get back on the brake and see if that works for you if you are wanting to spin for a long time.
I have spun in M and S the one time I went to the track. I am not 100% sure but I think I hold brake then floor it for a split second then let off some continuing to spin then let out of the brake pedal some and then completely off of it. I think I may go try a burnout a little later to see what I do and how long I can spin for in one place.
Old Sep 13, 2011 | 10:32 AM
2006 E55 AMG
I am going to try it on the way home tonight too
Old Sep 13, 2011 | 10:38 AM
GT-ER's Avatar
2005 E55 AMG
I can spin my tires as if my car had 1000hp...but aprox. 2 seconds afterwards will bog down and dead hook....lol. I've tried everything...the car hates me.
Old Sep 13, 2011 | 11:19 AM
  #32
GregMB's Avatar
The mystery gets stranger and stranger for mine (2006 E55)... I thought my car would ALWAYS interfere with burnouts, but now I'm not so sure.
The other day, I was at a dead stop and turned of ESP (transmission was in Sport mode) and tried to do a burnout. For the first time ever, I avoided the temptation to hold the brakes while initiating the burn..... I simply floored it.
WOW! The rear tires erupted into a cloud of smoke and the car started slowly creeping down the street. It was definitely several seconds of tire shredding before I lifted out of it and the electronic nanny was nowhere to be seen. Previous "hold the brake and burnout" attempts were always shut down within a couple of seconds, even with ESP turned off... though I think back on those attempts I was also in "Comfort" mode on the transmission, so that may have played a role also.
-G
Old Sep 13, 2011 | 12:52 PM
  #33
urbamworm's Avatar
Ok, I lied it does it to me too. I guess I never held the brake that long to stay in one place. I just tried it in M and S and it kills power after 1.5-2 seconds. You can hold the brake and get them started and then when you feel it start to cut power let off the brake and continue to blaze for a good while though. That should be enough to warm up your tires plenty at the track.
Old Sep 13, 2011 | 01:39 PM
  #34
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I have heard of some the newer class having the sam isues. I tried to run in dyno mode a few times but goes into limp mode. Burns out like a raped ape but then limp mode on launch.
Just to clarify, TC is off and tires are in the WATER and still the TQ takes over. It is real bad and som ofthis seems to be tied intot he ABC suspension. If I try to do a donut or some drifting, then TQ overrides system and cuts power get car back in stight line. STAR can remove this but when you turn the key off, it re-sets back.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 13, 2011 | 01:42 PM
  #35
LOCO 05' E55's Avatar
P-Carro
Originally Posted by chawkins2001
Sell just the hoosier tires
They are screwed into the wheels
Beadlocked
Old Sep 13, 2011 | 01:57 PM
  #36
Jakpro1's Avatar
2003 E55 & 2014 GL550
HigginsBeach was a madman. He sat in his driveway and practiced until he could put the car in and out of dyno mode in seconds.
He would do the burnout in dyno (everything off and tires on fire)....then roll forward, shut down and pop out of dyno in just a few secs.
Course nothing wrong with dyno runs in my eyes. You just gotta know the risks. No baby sitting if she gets sideways....no abs and I think maybe even no airbags. Scary. Done it several times myself with no worries.
Old Sep 13, 2011 | 03:15 PM
  #37
2006 E55 AMG
Beadlocked
pm me pics and pricing sir, and got your package
Old Sep 13, 2011 | 04:26 PM
  #38
PLATINUM SPONSOR
2003 CL55
Tried the dyno mode and it went into limp mode at launch. Not fun rolling down the track 35 mph.hehe
Here is another over-ride thing on the CL but it has its advantages. I can put car in M mode and it will still shift through each gear on its own. It just raises the shift points a few hundred RPM.
__________________
www.ultimatepd.com
Old Sep 13, 2011 | 04:30 PM
  #39
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
...Here is another over-ride thing on the CL but it has its advantages. I can put car in M mode and it will still shift through each gear on its own. It just raises the shift points a few hundred RPM.
my e does this as well
Old Sep 13, 2011 | 10:03 PM
  #40
P-Carro
would an open diff. solve your issue? is there one for the CL?..I had this problem and had to really fight to do a real burn out. Not only the one tire stopped spinning but the car would bog down as well. Quaiffe+Dyno mode for me and it occasionally goes on Limp mode, then just try it again until she learns where she is @ and why she is there
Old Sep 13, 2011 | 10:05 PM
  #41
P-Carro
Cool PM sent
Old Sep 13, 2011 | 11:11 PM
  #42
Benz-O-Rama's Avatar
Yup, same thing in the SL. I still do my burnout in dyno mode, but then I shut the car off and restart before I stage it.
Old Sep 14, 2011 | 09:54 AM
  #43
PLATINUM SPONSOR
2003 CL55
That settles it, I have to start practicing my dyno-in and out times! Ok, post your quickest You tube dyno mode on off times vid.. lol
__________________
www.ultimatepd.com
Old Sep 14, 2011 | 10:48 AM
  #44
Vossen Wheels's Avatar
Former Vendor of MBWorld
Various
Whoa!
Old Sep 14, 2011 | 02:07 PM
  #45
2006 E55 AMG
Originally Posted by Vossen Wheels
Whoa!
Southern Style
Old Sep 14, 2011 | 03:30 PM
  #46
Bramage's Avatar
F-250
I will be beating my PB as soon as we get some track time.
Old Sep 14, 2011 | 04:16 PM
  #47
ShangoAshe's Avatar
2020 AMG GT-R PRO
+1
Old Sep 14, 2011 | 04:17 PM
  #48
ShangoAshe's Avatar
2020 AMG GT-R PRO
I'm sure you will bud, you're gona kill it!
Hey Dane, keep the end of October open! Someone special might be coming down from Canada...
Old Sep 14, 2011 | 05:36 PM
  #49
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Thinking of heading up to the track this friday to get some times in. To those of you making sub 2.2s 60's how exactly do you pull that off? Do your tires chirp up a bit while accelerating cos last time I was out at the track I definitely could not pull sub 2.2 60's with my 285 T1Rs because I would let off the moment I heard the slightest chirp.
Also, what exactly is good/ terrible track prep? Thanks gents.
Old Sep 14, 2011 | 06:19 PM
  #50
chiromikey's Avatar
t1r's are my favorite street tire. i put the suspension in comfort, go around the water box and do a dry burnout for about 2 seconds in manual mode in 1st gear and esp off. i then put the trans back in sport mode and "d", do a shallow stage and launch from idle by firmly applying throttle (not quite a stomp). if there is some old rubber and vht on the track i ussually hook up enough to get low 1.7's and i never let off.
