175mm Pulley Boost
Old Sep 24, 2011 | 10:41 PM
Silverr1's Avatar
04' E55K
175mm Pulley Boost
Not sure if this is correct. I'm reading about 10.5 psi using the Torque app on my Android phone. This is pretty consistent at WOT.
My mods include LT EC headers, primary and sec cat deletes, x-pipe. Still have stock resonator and mufflers.
I've read that less exhaust restriction will result in lower boost pressures. I've read for a VRP 175mm pulley the boost rises around 4psi to around 14.2psi. Just curious is 3.7psi drop is inline with my mods.
thx
Old Sep 24, 2011 | 10:44 PM
AWOL's Avatar
e55
That seems a little excessive
Old Sep 24, 2011 | 10:57 PM
GT-ER's Avatar
2005 E55 AMG
That doesn't sound right. Your mods are nearly identical to mine and I see 13.5-14.5psi depending on the revs. My pulley is slightly larger ( 178mm ) but a 2mm difference in pulley is barely noticeable.
Old Sep 24, 2011 | 10:58 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Here is a log with "180" asp pulley which is actually 178mm where the belt rides. Kleeman headers, no cats and exhaust.
EDIT: Log is from the man above.
Old Sep 24, 2011 | 11:14 PM
Silverr1's Avatar
04' E55K
Here is a quick log from mine.
Attached Thumbnails 175mm Pulley Boost-screen-shot-2011-09-24-11.11.09-pm.jpg
Old Sep 24, 2011 | 11:15 PM
Silverr1's Avatar
04' E55K
Where should start looking? Belt, clutch? Any common areas where leaks happen?
thanks in advance
Old Sep 25, 2011 | 12:01 AM
I Like Soup's Avatar
2003 E55 AMG
thanks in advance
Maybe the app?
Old Sep 25, 2011 | 08:58 AM
GT-ER's Avatar
2005 E55 AMG
What are the numbers in the columns? Where are the RPMs?
Old Sep 25, 2011 | 09:29 AM
skratch77's Avatar
2005 E55
The torque app sucks for logging boost
Old Sep 25, 2011 | 11:41 AM
Silverr1's Avatar
04' E55K
I attached another one from today with the labels. I also included the MAF which reads 422 g/s which work out to .94 cfm or 26.624 lts/m. I also checkout my vacuum at idle and it's steady 20 inches of vacuum. I hope some of this data helps.
Attached Thumbnails 175mm Pulley Boost-screen-shot-2011-09-25-11.35.47-am.jpg
Old Sep 25, 2011 | 03:34 PM
GT-ER's Avatar
2005 E55 AMG
Sorry but those logs don't seem to make much sense. I think it's your logging application that's not right.
Old Sep 25, 2011 | 03:58 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Stock vs. 178:
image credit Marcus Frost
Old Sep 25, 2011 | 06:05 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Agreed. I haven't had good luck with it either. Try using intake manifold pressure since the vacuum/boost option has been problematic for me too.
Old Sep 26, 2011 | 05:05 PM
Silverr1's Avatar
04' E55K
Did another run using manifold pressure and got up to 26.4 psi or 11.7 psig. A little better but still not what others are seeing. Maybe just not the best logging tool.
Attached Thumbnails 175mm Pulley Boost-screen-shot-2011-09-26-5.01.06-pm.jpg
Old Sep 26, 2011 | 05:57 PM
BRABUS786's Avatar
Stage 3 63
hey
My 190mm pulley made 1 -1.1 bar boost
Around 14.5 to 15.7 psi
acid
