Squealing
ones and the asp pulley is much better. you can purchase just the idler it's 150 a pop or like 325 for the set of three. it's not on thier site so you have to call them
You can always just change out the bearing too if you have a press handy. They are like $5 on ebay.
https://mbworld.org/forums/w211-amg/...ng-repair.html
Where is the water pump pulley, did you fix the issue?
It's one of the first signs that the water pump is wearing, but because I don't have any leaking or wobble I just live with the squeal.
At least it may point you in the right direction, if it's not the pullies.
I thought for sure I had a bad idler pulley, replaced the bearing and everything. Then I figured I had some other pulley that was bad. I had the car at MB for something else and asked them to take a look and they said it was my belt and they would change it for like $350 haha. So I said no, took the car home and got some wd40 and gave it a little squirt on the belt and the squeak disappeared.. So I replaced the belt myself and it never came back
