Launching with Drag Radials
I remember when you said this a few years ago and i was running 25psi in my 275/30/19 street tires with a best et of 12.2 then I switched to 36psi and went 12.0. I also started running more consistent 60' with 1.8's vs 1.9's & 2.0's.
I've never tried 30+ psi in my drag radials
I know Alan cut a 1.62 in his car with my setup @ 20 psi
Tbal, get the psi up and start at 32psi and get in a couple of runs at that pressure then work your way down to 20psi. Every two runs drop 4psi, make sure that you heat the tires before your run with a nice burnout. Good luck!
Super Moderator
I usually did all my runs with dyno mode on, suspension on comfort, and raised as high as it would go. Usually had my tires right around 17-18PSI
Drive around the water box and back up, get the rear tires wet and then come out a foot in front of the water. Do a nice burn out for a few seconds until you can see a bit of smoke. Then let the car roll out. Slow on the brakes soon after and start creeping to the light. As soon as the first light lights up, slow down and as soon as the second light hits, stop. At the line and hit the gas pedal until you hit about 800-1k in the rpm's. Go on the second yellow light. Release the brakes as fast as you can and push the gas pedal like you were going to go through the firewall.
That's what I did and solid 1.6's all day every day.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2003 E55 & 2014 GL550
I'm with loco tbal. Some 55s just DIE when trying to burnout while some don't. We discussed this a year it so back. You may have to do burnouts in dyno or full runs in dyno. Higginsbeach could burn in dyno and pop it out in secs for run in normal mode. Amazing and harder than it looks with everyone watching.
Normally burnouts aren't a Problem... http://www.youtube.com/watch?v=DR0uG...e_gdata_player
Lol, your right at the track it's different. What's the difference driving through the water box ad driving around it and backing into it?
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#33
Bolton?? Quinton where you at boy...
Sneaky how's the Seattle track compared to the mission track? Do they have street legals/test n tune days?
#34
2003 porsche 996 turbo
i posted this somewere else but it applies here. i write my starting line list on a large postit note and stick it on the airbag in front of me. then go thru the list from entering the waterbox to staging. helps me to not forget something!
