E55 Exhaust System
Old Jun 7, 2003 | 06:58 AM
stephens's Avatar
E55, F550, S600 Ducati 999
E55 Exhaust System
Below is a pic (thanks Dr Chill) of the E55 factory crossover. This is not on the S,CL and SL55 and appears to be the only real difference in the W211 exhaust system.
My question is what potential issues its removal could have?
I am not sure whether to remove it entirely along with the intermediate muffler, or to remove the crossover pipe and replace the intermediate muffler with a properly designed crossover pipe like that on the M5.
Old Jun 7, 2003 | 07:20 AM
stephens's Avatar
Below is a diagram of the SL etc exhaust system (it's actually an AMG E500 exhaust system, but aside from diameter there is no difference to the best of my knowledge)
Old Jun 7, 2003 | 09:46 AM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
Isn't a crossover pipe a good thing? In US cars, it improves performance. Why do you want to remove it?
Old Jun 7, 2003 | 10:31 AM
Ronald's Avatar
Mercedes-Benz SL 55 AMG (R 230) and CLK 55 (W 209)
I agree. In Germany, many people go to MKB and get a crossover-pipe for their SL 55s.
Ronald
Old Jun 7, 2003 | 10:34 AM
stephens's Avatar
A properly designed crossover pipe designed like a collector would be great eg. merging to the two 2.75" pipes to a single 4" pipe and back to two 2.75" pipes.
I am not an expert on exhaust design, but the standard crossover pipe looks like a flow killing, turbulance inducing nightmare. I would like some more knowledgable opinions on the matter.
Old Jun 7, 2003 | 11:22 AM
Symbolic's Avatar
BMW M5, Porsche 911, Mercedes-Benz E55
Re: E55 Exhaust System
I'm told that there's a diameter difference between the W211 E55 exhaust system (i.e. 70mm) and that of the SL55-CL55-S55 cars (i.e. 90mm), because of the space constraints/clearance problems of the E55 platform.
Old Jun 7, 2003 | 07:03 PM
stephens's Avatar
I had heard that there was a difference in the rear section as you have stated, not the full system, but I had a look at a CL at the dealership and it appeared to be the same as the on the E. can a CL owner confirm this?
Old Jun 7, 2003 | 07:17 PM
Rennteam's Avatar
Porsche 997 Turbo
Ronald
Is it street legal too?
The crossover-pipe is not enough I think, what about the silencers? I heard a modified SL55 a while ago and I loved the sound. Not sure if it was modified by MKB parts though.
Old Jun 8, 2003 | 01:05 AM
Dr Chill's Avatar
Porcelain Bus
Crossover pipes were discovered back in the early days of American musclecars probably by accident. The main purpose of a crossover pipe is to equalize exhaust pressures between the two sides and eliminate any unappealing resonating frequencies or gurgling sounds. The biggest improvement seen is a much cleaner QUIETER idle and a more pleasing (but not louder) exhaust note at all engine rpm's. The pipe should be the same diameter as the exhaust and should also come off the pipes at as small an angle possible. This will also cause a very modest gain in performance as it scavenges the cylinder banks of exhaust gases more evenly and efficiently. To my eyes, the factory crossover pipe appears slightly smaller than the exhaust pipe but based on this photo it might be an optical illusion. IMO replacing this pipe with one of any other design will make minimal difference and doesn't justify the cost or effort. It might be more worthwhile to increase the pipe diameter or replace the mufflers with more free-flowing ones.
Old Jun 8, 2003 | 04:10 AM
stephens's Avatar
I am going to remove the intermediate muffler all together, but am also considering removing/replacing the factory crossover pipe.
Old Jun 8, 2003 | 06:36 AM
mbprince's Avatar
one of seven
Dr Chill - homerun with that explanation on the crossover!!!!
