Passenger headlight issues
Old Oct 13, 2011 | 11:16 PM
AWOL's Avatar
e55
I think my car is mad at me that I listed it for sale.
A couple days ago, my right headlight would start to flicker. I have an aftermarket HID kit so I thought it was just on its way out.
Well, long story longer - its not the bulb, and its not the ignitor. I swapped both from the other (working) side, and it still isnt working. They turn on just fine with the car off. I start the car, it flickers a little, I bring the revs up (in neutral) and it goes out, like clockwork. Every time.
I checked the connections, checked everything under the hood. I ordered a new voltage regulator for the alternator a days ago - prior to this problem, but Im getting 14.1 volts while driving so Im not sure thats the issue.
Just looking for some tips here, maybe a fresh idea of where/what to look at.
Again,. only passenger side has this issue.
Old Oct 13, 2011 | 11:30 PM
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
Did you check the control modules, my headlights were having issues too and replacing them finally cured it. They're the silver boxes mounted underneath the headlights.
Old Oct 14, 2011 | 02:51 PM
AWOL's Avatar
e55
How would I go about testing them? I didnt notice any other modules besides my aftermarket kit
Old Oct 15, 2011 | 04:44 PM
AWOL's Avatar
e55
Need help here people. I installed the new VR, but still:
Im getting 12.3 volts with the car off.
Im getting 13.4-13.6 at straight idle
Im getting 12.8 volts at idle + headlights on, before they turn off
Should they draw that much voltage? Seems excessive.
I get a good 14.1-14.3 driving + no headlights. My headlights go out when I rev it
Old Oct 15, 2011 | 04:57 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
35w bulbs? I do not have any issues with my 55w kit, but had flicker and error code with my 35w kit.
Old Oct 15, 2011 | 05:19 PM
AMG_RL's Avatar
You have to take off the bumper and pull the headlights out. There should two silver modules mounted on the bottom. Swap them between the working one and see of that solves it. FYI, if that is the issue its an expensive fix, my indy charged me $850 for a new one.
Old Oct 15, 2011 | 05:29 PM
AWOL's Avatar
e55
Its a 55w kit. I can run straight high beams, if I unplug the low beams.
Do those voltage numbers look like what they should at? Can any of you fine gentlemen report back with your voltage numbers, at idle and no lights, and idle with lights?
Im trying to isolate the problem, whether its my alternator not making enough juice, or just a headlight issue.
Car runs fine, just cant drive it at night
Old Oct 15, 2011 | 05:32 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
I dont think he has the silver boxes. He has aftermarket xenons.........not factory. That is a factory box for the lighting package you are refering to.
Old Oct 15, 2011 | 05:36 PM
AMG_RL's Avatar
Oh got it, thanks for clarifying I must've missed that.
Old Oct 15, 2011 | 05:38 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
I could be wrong here, but I am pretty sure AMG RL is getting confused about the metal boxes under the light. That would be the ballasts (control module) for the lights mounted to the bottom side of the light for a factory xenon/hid headlight. Since the OP is saying he has aftermarket hid in the car (meaning it didn't come with hid lights) then he wouldn't have those boxes under there.
EDIT: damn it, it was already explained.
Old Oct 15, 2011 | 05:40 PM
AWOL's Avatar
e55
whew, thanks guys. Yeah, aftermarket kit. Swapped ballasts, still same side with the issue.
Old Oct 15, 2011 | 05:52 PM
urbamworm's Avatar
To me it seems like there is a short in the stock harness if you swapped ballasts and the same thing happened. It seems like the logical thing at least. You didn't happen to notice anywhere that the wire was messed up somewhere or the plug had something going on? How long have these lights been in the car?
Old Oct 15, 2011 | 05:54 PM
AMG_RL's Avatar
yea sorry Scott I missed the part where u stated it was an aftermarket unit. Hmmm have you checked the wiring for voltage? My race car had faulty wiring which led to a headlight not working, everything else seemed to be working fine and it came down to a freakin .40 cent piece of wire causing all the headaches.
Old Oct 15, 2011 | 05:56 PM
AMG_RL's Avatar
We're on the same page buddy lol.
Old Oct 15, 2011 | 06:04 PM
AWOL's Avatar
e55
Ive been running this same brand since I bought the car. I bought new ballasts and new bulbs maybe over a year ago. Ive checked all the wiring I could, and dont see anything a miss.
If the car is off, eveything works. If I start the car, they work, I rev it up, it goes out. I keep the car running, drop revs back to idle, turn the lights off and then on again and they work again. It has something to do with the engine speed, but even then Im showing 13.8-14.0 volts which is plenty to keep things energized.
