Replacing ball joints, need some help
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
I decided to tackle my front ball joints today as they have been squeeking for quite some time. anyways, I followed the instuctions on this link: https://mbworld.org/forums/e-class-w...oint-w211.html
the problem I am having is removing the old ball joints. they seem to really be stuck in there I was wondering if anyone else has this issue or was the press relatively easy to use? I don't want to break anything and it seems like I have to use alot of force to press the old ball joints out. any tips? I already broke it loose from the knuckle.
Thanks bro. Yea i used a breaker bar as well and that sucker still doesn't want to budge. I think i might try to borrow some impact tools to get it off.
E55 w/ goods, Z32 Project underway
As long you you are using a professional grade ball joint separator removing it does seem like you are about to brake it but just when you think the tool is going to give BAM!! and it is violent, the bal joint pops out. Removing them was realtively easy compared to pressing them back in. get a LONG braker bar and then steel piping to use and an extension, you'll need it!
The kit I used was purchased from Harbor Freight, worked great. I used the handle from my aluminum floor jack as the breaker.
Haha okay that makes me feel better about tackling this again. The seperator I'm using is the rental from autozone. Gonna go for impact tools for sure to make life easier
Was it this one
http://www.harborfreight.com/four-wh...-kit-4065.html
Or this one
http://www.harborfreight.com/3-in-1-...kit-38335.html
Or this one
38335 is what I used, have to get it on there just right considering the amount of torque required, use a 20% coupon for savings
Well I finally got them out!! It took me and my buddy two big *** cheater bars to remove the passenger side, the driver side was much easier to remove. You guys weren't joking that thing OS like a 12 gauge going off!! Haha thanks for the help guys
Would someone be able to buy this kit for me and send it to me in Australia?
Harbor Freight dont deem to send out of the country.
edit: just emailed them and waiting for a reply.
Lower ball joints were $46 x 2 from autohausaz.com, rented the ball joint press for free from autozone, and had to buy the ball joint separator from winchester auto for $79. In the end though it was about 1/5 the cost a local dealership quoted me.
I went with the Meyle Heavy duty ones, they're working very well so far. as far as symptoms, squeeking all the time and the ride was beginning to get a bit choppy. it definately felt a lot smoother with the new ball joints, the old ones were completely shot.
