E55 Brakes
The current amount in parts alone for a full set of front and rear discs and pads for the E55 is something approaching $1000.
Are there any good alternative suppliers of OEM parts?
Or can I get some decent two piece rotors for decent money?
Fitting is no issue, thats an hour in my sweltering hot Texas garage.
If your brake light has not come on yet, then reuse your sensors. Don't forget the anti-squeal paste.
Rear: https://www.racingbrake.com/Two-piec...EAR-p/2188.htm
See our complete brake offer for "E"
https://www.racingbrake.com/category-s/7264.htm
Rotors/pads were $474, parking brake kit (shoes/springs) was $74, caliper bolts were $22 at the dealer, taps were $7 to $10 each. You're going to want "plug taps", not "taper taps"; the rear brake shield prevents a regular taper tap from completely clearing the threads of microencapsulation.
https://mbworld.org/forums/w211-amg/...ml#post7160126
You have to shop around, get these parts from here and there. I bought my front rotors off of eBay. Pads from Rock Auto, brake hardware from FCP Euro. Antiseize compound and Brake Quiet paste from Autozone.
So I can be done, you just have to be smart with your money and shop around.
Nobody will take care of you like they will: https://www.fcpeuro.com/page/lifetime-guarantee
For most people akebono and ceramic brakes are a good choice fir minimal dust..
What do you mean by this exactly then?
I think we can all reasonably assume brake fade is pretty standard on street cars for track application.
Others care to chime in with their experiences here?
I know of only one person out there using their E55 for dedicated track use, the individual detailing the oil pump O-ring failure on M113K motors on YouTube.
I'm not here to convince you of anything, I was curious why you thought that and what your reference point was.
Speaking of what, what other cars have you tracked and how does the E55 experience compare to those?
Blasting down a straight away, heading into the corner and you get on the brakes and there nothing. Brake fade is a *****, especially when a barriers are coming up fast.
