Airmatic Question???
Old Oct 27, 2011 | 01:03 AM
Pinknuts's Avatar
'06 Black Opal E55 AMG
Hey guys, just have a quick question on my car. I've noticed since I bought my car that sometimes when my car sits over night or for a descent amount of time, the rear suspension sags. As soon as I unlock the car the sensor picks up that its low and lifts back up. Is this normal or do I have a leak somewhere
Has anybody else had this problem or heard of this?
Thanks in advance.
Old Oct 27, 2011 | 01:06 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Happens on my car.. Pretty sure its normal.. At least its been doing this for over a year now on my car..
Old Oct 27, 2011 | 01:21 AM
Pinknuts's Avatar
Ok I haven't had the car long so didn't know if it was normal or not. I really noticed today after work since I've lowered my car already. It was tucking tire in the rear pretty well.
Old Oct 27, 2011 | 01:40 AM
AKnight55's Avatar
I mean if its doing that only after a day of sitting you may have an issue.. Mine does it when I leave it in the garage for about a week or so at a time.. Or especially in the cold weather it does it.. As long as it goes back up to the normal height when you start it then I would say everythings fine..
Old Oct 27, 2011 | 03:29 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
it's the early sign of an air spring failure. it can over work your air compressor as well as cause premature tire wear, even if it appears to raise back to normal height as soon as you open the door. just replace it as soon as you can to avoid getting stranded.
Old Oct 27, 2011 | 08:02 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
+1. If your car has to pump up every morning, you have a problem.
Old Oct 27, 2011 | 08:03 AM
Hellzno's Avatar
E55 AMG
mine has been doing this as well. anyway to test where the leak could be?
Old Oct 27, 2011 | 08:07 AM
novae500's Avatar
W211
get that checked out to avoid it being slammed one day and can't drive it to the shop for repairs.
Old Oct 27, 2011 | 09:06 AM
Pinknuts's Avatar
OK I will get it checked out today perhaps. I'm getting an alignment at the dealer anyway. I wonder if my extended warranty would cover that?
Old Oct 27, 2011 | 09:07 AM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
I was told that it's normal.
Old Oct 27, 2011 | 09:24 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
This is a normal function of the air suspension.
Old Oct 27, 2011 | 09:57 AM
Pinknuts's Avatar
Well that sucks if its normal. It just looks awful being so dumped in the back after just sitting over night.
Old Oct 27, 2011 | 10:07 AM
GT-ER's Avatar
2005 E55 AMG
It's NOT normal for it to happen over night. You have a leak somewhere.
My car does it if I leave it off for a week or two...but not over night.
Old Oct 27, 2011 | 10:09 AM
moosejaw's Avatar
none
Looks like a old lincoln right?
Old Oct 27, 2011 | 10:15 AM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
just got back from china for 10 days and the rear was very low but went back to normal . this is ok then?
Old Oct 27, 2011 | 10:16 AM
There is a test that is done with STAR that measures recovery time and pressure for the air pump and air tank. To find a leak in the lines and junctions go old school, soap and water in a spray bottle.
And a lift that keeps the weight of the car on the wheels is a good idea too, when looking for a leak.
Old Oct 27, 2011 | 10:18 AM
GT-ER's Avatar
2005 E55 AMG
Yup...
Old Oct 27, 2011 | 10:21 AM
Yuille36's Avatar
It is normal for the suspension to drop a little bit, but not to for it to be slammed. if it is slammed then your right there is a leak in the system, typically its the rear airspring that went bad, but the system needs to be fully checked out by a tech using Star.
Old Oct 27, 2011 | 10:22 AM
ertech's Avatar
anyone know the prodedure with star?
Old Oct 27, 2011 | 10:25 AM
Pinknuts's Avatar
Here is a video I took this morning after it had just sat overnight.
http://static.photobucket.com/player...7-08-40-02.mp4
http://www.youtube.com/watch?v=XTeXjMYdIis
Old Oct 30, 2011 | 12:08 PM
SamBoler's Avatar
W211 E55
Member - "Grimm" is swapping suspension soon so hit him up if you want his rear air shocks
Old Oct 30, 2011 | 01:35 PM
chiromikey's Avatar
yes, you have a leak...and i wouldn't bother getting an alignment until you get that fixed.
Old Oct 30, 2011 | 03:37 PM
Pinknuts's Avatar
OK awesome. Thank you very much.
Old Oct 30, 2011 | 05:19 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
defo a leak there
Old Oct 30, 2011 | 06:29 PM
outrun's Avatar
2004 E55
Damn! How many dead hookers you have packed in there? 10?
